SSAC likes to make different designs and some dont fit! for instants my SSAC top mount sr20 mani...had to mod flange to the head, i got another one and it fit fine! my ca18 one fits fine but i also hear of peopel like u where they dont fit. u probably got the one that was dropped and it bent the flangeslideways wrote:THERE IS NO MODIFICATION NEEDED TO FIT THIS MANIFOLD BESIDES RELOCATING HTE RUBBER VACHOST THAT GOES FROM THE HEA DOT THE INTAKE AND CHOPPING THE OIL DRAIN LINE FROM THE TURBO AND USING RUBBER HOST TO CONNECT IT TO THE PAN.
serriously man i am running the same set up and i ran into NO problems. only thing that you weld expect. customizing the things took me but a near 30 minutes to conclude. not trying to talk you out of selling just leting you know that its not a hasstle, well worth the install
brandon
I fitted a manifold, elbow and full exhaust set for a customer last week, the fit was..........interesting8ggalant wrote:items arrived in still original packing...thanks again
off topic ...has anyone used a ssac dp...this one is a one piece (dp and test pipe)...just wondering about fitment....i guess we'll see when i put it on...just wondering if anyone here knew
With manifolds like that being SOOOOOOOOOOOOOOOOOOOOOOO close to the valve covers, should some type of heat shield/baffle be implimented inorder to reduce the radiated heat going to the valve cover??float_6969 wrote:Mine is very close to the valve covers, but doesn't touch. I'd say I've got 2mm of clearance.
