FS: S14 Kouki track car (SR20DET, caged)
Buy or sell Nissan / Datsun cars, trucks, SUV's and crossover Vehicles!
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
Postby 0wn3r » Fri Nov 15, 2019 1:05 pm
$13,700 OBO - located in CT. NO trades, NO part-outs.
--97 240sx SE (zero rust issues and no other issues that would prevent you from tracking it today.)
Great car that I've owned and built up over the years (long-time owner of the car and IIRC only the 2nd owner after purchasing it stock in FL). Clean title FWIW.
Engine/Fuel/Performance:
--Same gen SR20DET but w/ S15 turbo (Swap by CIP Motorsports / 240sxMotoring)
--Power FC dyno-tuned by Dentsport (Very conservatively to 240hp/260tq at the wheels @15psi on 93 octane)
--550 cc injectors
--Walbro fuel pump
--Recirc BOV
--Undersized (lightly) crank pulley
--ACT clutch
--Z32 MAF with Apex'i intake kit
--Koyo radiator
--Greddy FMIC
--Battery relocation kit, to trunk
--Circuit Sports 3" exhaust, w/ test pipe (sounds great, no dB concerns)
--VLSD
Interior/Safety:
--Gutted with a full cage (built by CIP/240sxmotoring). POR15 most of the interior
--Driver's side: Sparco Evo seat (newer) on Bride adjustable rail, window and seat nets (not pictured)
--Passenger's side: Sparco Evo seat (older) on fixed Planted rail
--G-Force Pro 6-point harnesses
--Driven steering wheel (removable)
--Keyless ignition
--Battery kill switch
--STRi boost, oil pressure, water temp gauges
--No heat or a/c, removed for track use but still have some parts
Wheel Tires/Suspension/Exterior:
--17x9 Enkei RPF1s
--255/40/17 NT01s (life left)
--ARP extended wheel studs
--NovusTech hub-centric 15mm spacers (front)
--Front suspension: (veilside180sx mounts) Bilstein shocks, Ground control camber/caster plates, H&R springs
--Rear suspension: Koni yellow shocks, Tein top hats, H&R springs, Cusco RUCAs
--Seibon carbon fiber/fiberglass hood w/ locking Aerocatch+ pins
Brakes:
--Front: Wilwood Forged Superlite calipers, two-piece rotors (w/ BNIB spare rotors & some hardware), Defsport hats & brackets
--Rear: Z31 bracket/Altima rotor setup
--Hawk HT10s (on the car) and spare DTC60s (currently off the car)
--Stainless brake lines
All of my extra 240sx parts will be included with the car)
I've since removed the vinyl "244"s. The paint is in great condition.
Reason: SOLD
0wn3r
Re: FS: S14 Kouki track car (SR20DET, caged)
Postby 0wn3r » Sun Dec 01, 2019 10:52 am
I haven't been on NICO in a while and can't seem to find where I can edit my OP.
PRICE DROP! - $13,200 FIRM
0wn3r
Postby 0wn3r » Mon Dec 09, 2019 8:37 pm
SOLD!
Return to “Nissan For Sale”
