The plug you have circled is for the ignition coil subharness.ca18detdrift wrote:I'm trying to figure out where it plugs into as well, this is what my harness looks like, there is only one plug where this seems to fit but i know this is for the coilpack harness (unless im wrong). I dont see any plugs that it'll fit into near the MAF.
He has an automatic wiring harness. That is the resistor pack for the auto transmission.float_6969 wrote:I have circled where it should be and something that looks wrong with your harness...
I don't have any DSM ones, but I do have some Honda 2.5 ohm resistor packs. Same thing...qwade25 wrote:I've done a CA swap also. My harness didn't come with that. Do you still have that?
I COULD. But if I sent it out priority tomorrow morning, you should get it by Tuesday. Contact me at chris @ escic.com and we can work out the details.Not_a_sr wrote:Crad, would you do 10$ plus 13.85to put it into a express flat rate envelope on tuesday? i need one for a 800hp thunderbird project. its a high impedance car and only injectors large enough are low impedance
