FS: CA A/C compressors, power steering pumps.
fanta
Two of each, all have mounting brackets. I believe there's a pump reservoir as well, I'll have to check. Don't really have a need for them as my car has a steering box and doesn't even have a heater core. Pics can be provided.
crazymax
Car: 89 coupe
PS pump mounting brackets..email?
fanta
TeckniX
How much you want for the power steering pump - is it hicas or non-hicas version?
fanta
TeckniX wrote:How much you want for the power steering pump - is it hicas or non-hicas version?
How can you differentiate the two styles? What is your e-mail?
TeckniX
email me lokitek(at)gmail.com - Send me some pictures (different angles) and I'll tell you what you got - Basically 1 power steering screw with a whole in it, instead of 2. Let me know either way, and also how much you would want for it shipped to 45014 - Thanks
fanta
I took a look at both pumps today- there's some differences between the two First pump, bracket and reservoir. This pump is much larger than the other. Is this the HICAS pump?
Second pump and bracket. Only two lines go to the pump.
mbmbmb23
Do you have the line coming off the AC compressor as well?
fanta
mbmbmb23 wrote:Do you have the line coming off the AC compressor as well?
I will check today. Pretty sure they're in a box somewhere.
TeckniX
Cool well first pump is a HICAs.. second one isn't. See how one has only 1 power steering line going to it, and the other one has two?Well I want the one that has only one, ie non-HICAs shipped to 45014 Thanks.
fanta
TeckniX wrote:Cool well first pump is a HICAs.. second one isn't. See how one has only 1 power steering line going to it, and the other one has two?Well I want the one that has only one, ie non-HICAs shipped to 45014 Thanks.
E-mail sent
TeckniX
This pump is sold...to me
