FS: 1996 Nissan 240sx (819wHP VH45DE Turbo)
Buy or sell Nissan / Datsun cars, trucks, SUV's and crossover Vehicles!
Jeff Taylor
Car: '96 240sx, VH45DET, 819wHP
Postby Jeff Taylor » Tue Mar 05, 2019 6:55 pm
I am sad to say that I am letting go of my 1996 Nissan 240sx. This car has been lots of fun. After finding the stock-internal limit of my VH45DE to be 819wHP, and watching the rotating assembly put 2 holes through the engine block, I have not had the time to swap another engine back in. The car basically went straight from the dyno room back into my garage, where it has sat for 8 years now. :frown:
The engine's internals were ALL stock, so swapping in another used stock engine should be all it takes.
Anyway, here's the high-level specs:
Engine: Infiniti Q45 V8 (4.5L, DOHC, ALL STOCK)
Transmission: 300zx twin turbo 5-speed
Clutch: SPEC stage 5 sintered iron disc
Transmission Adapter: Water-jet cut adapter plate, milled bell housing
Engine & Trans Mounts: Custom, solid steel mounts
Turbo: Garrett 72mm from a Detroit Diesel engine,
60mm wastegate with external dump
Intercooler: 24” x 12” x 3” fed by 3” mandrel-bent tubing
Fuel: E85 or 93 octane
Engine Management: AEM EMS, Low-Impedance Injector Driver Board
Fuel Injectors: 150 lb/hr low-impedance
Fuel Pumps: 3 parallel in-tank Walbro 255HP's staged at boost levels
Fuel System: -10AN Feed to Aeromotive fuel pressure regulator
Cooling system: Radiator relocated to trunk to make space for turbo
Driveshaft: Custom
Intake Manifold: Custom, CAD CFD-Designed, short-runner, balanced plenums
Exhaust Manifolds: Stock tubular manifolds re-designed to point forward
Exhaust: 4” Diameter w/ resonator & muffler
Rear End: Stock, welded spider gears
Interior: 10 point 1-3/4” roll cage
Included Extras: Many extra Nissan parts in my garage! I have a lot!
Power: 819 wHP / 727 wTQ @ 20psi boost (stock rods broke)
759 wHP / 685 wTQ @ 18psi boost
Pictures/Info: https://drive.google.com/open?id=16_D7T ... gl-askfJe4
Keep in mind the car has been sitting for 8 years in my garage. It is dusty and dirty. This car is the opposite of a "show car", but I have never been one for body work.
Last dyno pulls:
Reason: CLOSED
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2012 Honda CR-V LX
Re: FS: 1996 Nissan 240sx (819wHP VH45DE Turbo)
Postby Rogue One » Tue Mar 05, 2019 8:48 pm
Please follow all classified section rules: **FORUM RULES FOR POSTING TO CLASSIFIEDS**
2. CONTACT: Provide a specific method of contact for potential buyers to reach you. New members with less than 10 posts cannot send you a PM. Additionally this thread can be read by non-members, and they can't PM you either.
5. PRICE: Include a price, plain and simple.
NOTE: There's a TIME LIMIT for editing posts. If the edit button is gone, the post cannot be edited. Simply add changes as replies to your original post.
How to upload pictures on NICOclub:
using IMGUR
using TINYPIC
Jeff Taylor
Postby Jeff Taylor » Wed Mar 06, 2019 6:58 pm
Asking $6,000 OBO. Swap in another $200 used engine and let 'r eat again! Includes car and many Nissan-related extra parts.
See profile for my email address.
Jeff
Reason: Edited
Jeff Taylor
Postby Jeff Taylor » Sat Mar 09, 2019 2:10 pm
Now asking $3000 OBO
Jeff Taylor
Postby Jeff Taylor » Mon Mar 18, 2019 5:11 pm
Now $2,000 OBO. Here's some pictures of the condition it's in.
https://drive.google.com/open?id=1-Cj2k ... IGwHrZ2tYm
Price includes any other Nissan parts I have in my garage (MAF's, injectors, ECUs, engine heads, alternators, PS pumps, AC compressors, starters, etc). The garage needs to be cleaned out!
HG50
Car: 91 Q45
15 4Runner
Postby HG50 » Fri Aug 16, 2019 12:25 am
What ended up happening to this car?
Return to “Nissan For Sale”
