About frozen doors and locks. Here is what I learn from my mishap with my door handle not working, and me opening the doors panels and window assembly.
accessing-inner-driver-door-t596766.html
Firstly, when it is cold outside and water enters the door, via the window or otherwise, it can drip down the latch assembly, on either of 2 rods or a cable. When the water enters there and then freezes, two things can happen.
-the metal
rod connecting the
key mechanism to the door lock, or the other
rod connecting the
handle mechanism to the door lock can freeze and either one can "pop out" of their anchors, at either ends, because the ice expands and pushes them out. I saw it myself yesterday when I fixed my door handle. It is a very easy fix. Just reconnect the end of the rod to the mechanism by inserting it in the right place and using a tie wrap. The video in the treat above shows it clearly.
-The wire that attaches the door handle to the lock may not slide properly. One of its end can "pop out " of its anchor and detach and the handle won't work anymore. This is exactly what happened to me: I wash my car and right after I drove it in -30c weather. The cable froze, I then activated the handle by later opening the door when the car rested outside all night, and the end of the cable detached.
I opened the door inside panel, disassembled the whole window assembly, reached the various locking mechanisms, and now fully understand its workings. It wasn't a long but yet an easy fix. I could see some ice already forming on the rods and "pushing" their ends out of their "sockets". In my case, it didn't do anything yet but it could have (my problem were the cables, not the rods). I spray rust prevention liquid all over.
Lessons learned: don't wash your car in freezing cold weather as it may not only freeze the door, it's lock, but also the inside mechanisms.
