My front struts are so bad.. I'm no mechanic and seeing the pictures in this thread scare me.
removing-oem-cartridge-from-front-strut-t584131.html
I've done the rear struts, timing belt, main seal, cam seals, power steering rack, power steering pump, alternator, water pump, thermostat, rotors, pads, belts, EGR pipe cleaning, spark plugs, and I also changed the passenger side front strut mount a year ago because the bb's came out. But this has me all stressed out.. Its my daily driver. I feel I'm going to run into an issue and not have a car for a few days. My plan is to do one side each day so I can use the car the next day.
I bought KYB's 365056 because I couldn't find Monroe 73948 anywhere.
Anyone know which boots I need? Amazon says KYB SB104's are frequently purchased with 365056's.
Anyone have a shim size I'll need on the top? I bought the copper shims mentioned in the other thread but those won't work on the 365056's. They fit but only leave like 3 threads showing. No good.
Any advice?
