Front spring question
J30inthe sun
Car: 1997 J30
When i bought my 97 J30 it had 40,000 miles on it in August 2000. intially the car pulled slightly to to right. The dealer I bought it from tried several times to align it but could not get it right due to the front right being out of camber or caster, whichever one that there is not any adjustment for. So they replaced the whole front right strut assembly with a used strut unit which fixed the problem.
I am going to replace the front strut inserts, mounts & rubber pieces now.
My questions is since I do not know how many miles I have on the front right spring (the front left has 108,000 on it) should I replace the springs as well? Anyone know how many miles the springs are rated for?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
You are in FL? No signs of rust on any suspension parts and the car rides OK now, worn struts aside? How much are new springs?
Did you do your timing belt and how are things with the new TPS? Sorry for all of the questions.
J30inthe sun
Car: 1997 J30
GerryO wrote:You are in FL? No signs of rust on any suspension parts and the car rides OK now, worn struts aside? How much are new springs?
I am in Tampa. No signs of rust anywhere. I am the 2nd owner, bought the car in Tampa & the original owner bought it from a stealership in the Miami area & had all service done there. The car rides good now that I replaced the tension rod bushings today, however there is still a slight low pitched rumble from uneven roads (maybe something is loose, but i just had the shop check the front suspension for anything that needs replacement, ie worn suspension components & they said everything looks fine)
New springs are $150 each (I am tempted, its going to be @ $500 plus $150 labor for the strut insert cartridges, strut mounts, upper seats & boots.)
I just did the timing belt today (timing belt, tensioner idler, upper idler, water pump, thermostat, water inlets, camshafts seals, crackshaft seal, all accesory belts, fuel filter, tension rod bushings & spark plugs for $633 in labor at Z Fever in Tampa. I supplied all the parts)
The TPS worked out fine after adjusting the position of the unit after a few trail runs, no more CEL, idles perfect & shifts fine.
Modified by J30inthe sun at 8:50 PM 9/17/2008
Modified by J30inthe sun at 8:52 PM 9/17/2008
gr8scott72
Car: 1994 Infiniti J30t
J30inthe sun wrote:When i bought my 97 J30 it had 40,000 miles on it in August 2000. intially the car pulled slightly to to right. The dealer I bought it from tried several times to align it but could not get it right due to the front right being out of camber or caster, whichever one that there is not any adjustment for. So they replaced the whole front right strut assembly with a used strut unit which fixed the problem.
Have you replaced these:
http://www.fuzzycats.com/docs/...t.pdf
J30inthe sun
Car: 1997 J30
Yes. see my post before yours.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I Have a matched pair of front springs from a T with 112,000, send me an E-Mail if interested.
J30inthe sun
Car: 1997 J30
Gerardjg wrote:I Have a matched pair of front springs from a T with 112,000, send me an E-Mail if interested.
For an extra $300 I'm going with brand new.
Thanks for the offer though.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Are t springs/struts stiffer than standard/non-t springs/struts?
driverdriver
Car: NICO's longtime resident Canuck!!!
Yes for '93 and '94 models.
