Front Endlinks Help!
SneakyFish
Car: 2008 Altima Coupe 3.5SE CVT
Got my front endlinks from the gb and tried to install them yesterday but the bottom bolt wouldnt lose or turn at all. I tried using rachet, wrench, impact gun and anything else i could think of. so my question to everyone is what should i do or try next? if you have the front endlinks i would really appreciate it if you told me what you guys did. sorry for the long read.
mcheddadi
Car: R8
use lube and a more powerfull impact wrench lol
maybe you tightened it instead of unscrewing it.
you can always use a torch to heat it up and then use a wrench on that dilated sucker
SneakyFish
damn forgot to try lube. a stronger impact wrench? im pretty sure im using like a 2hp compressor (whatever that is for psi). as for the tighten instead of unscrewing, i tried both ways just in case lol. that torch idea isnt bad for a last method though
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
wd40 ???
