OK, when I read this I thought “no way this will fix my problem!” I had already replaced both CV joints (one was bad, so I replaced both) and I replaced both wheel bearings (again, one was bad). But then I had this silly poping noise when shifting from reverse to drive and vice verse.
Could not figure it out and nothing was making sense, then I can across this post and thought, “what the heck it’s pretty simple and I’ll only be out my time for trying.” Well, 20 minutes later and the noise is gone!
Now, I took a bit more of a redneck approach using my finger and a glob of grease and applied liberally to both sides of where the CV meets the hub bearing. I still cannot explain how it works, but it does.
If you have an unexplained poping noise on the front end of your Murano when you switch from drive to reverse and vice versus, you gotta try this fix!
Thanks for the great post!!!
