schyawn »
https://forums.nicoclub.com/schyawn-u6469.html
Tue Sep 16, 2003 10:21 am
Hey, it's not bad if you know a couple things: Just put the Front cover back on with some new liquid gasket all the way around. (Removing old gasket with scraper. Put all the bolts back in. dont forget the oil pan bolts.
I assume your oil pump is off of the front cover...ok, if not, you probably had a hell of a time getting the cover on. Make sure Piston#1 is at Top dead center on the compression stroke. Use a screwdriver through the spark plug hole. You can also temporarily put the crank pulley back on and line up the pointer on the front cover to the second mark from the left on the crank pulley.
ok. line up the marks (2) on the shaft of the oil pump, and the oil pump spindle. then insert it up throught the hole. Don't bolt it down totally yet, you probably didnt' quite get it right (It took me 3 tries).
I assume the distributor is off, if not, put some matchmarks on it and the front cover so you can line it up when you put it back on.Take it off.
Now, with the distributor off, you should see the end of the long shaft coming up from the oil pump. it has a tab sticking out of the end, this tab should be pointing to approximately 11 o'clock, perhaps a little to the right of 11 o'clock. If not, pull the oil pump out, and try again.
Once you have that tab leaning towards 11 o'clock. you can put the distributor back on. point the contact point of the rotor towards 4 o'clock or so, and then slide it in. If you had the matchmarks, match 'em up. If not, you'll need to set your ignition timing with a timing light. Or play with it a bit to get it running well enough until you do get one.
Tighten down the oil pump and distributor, put everthing else back on, fill oil coolant, etc.
Say your prayers, and start her up. I recommend getting an FSM (factory service manual), but even with that, i had to go to Nissan to get some things clarified before I could finish my timing chain job.
Good luck.Sean
