NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu May 06, 2004 9:38 am
use a screw driver and a hammer. hit it on one side of the plug to spin it in the hole. Grab it with a pair of pliers and yank it out. to install a new one use a socket that just fits inside the outer ring of the freeze plug and tap it in. dont hit it to hard as you could knock it clean through the whole. hit it till the lip of the outer ring is flush with the bottom of the taper around the freeze plug hole.
