Footwell Accent Lighting tutorial
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
homero89
Car: 09 Versa HB 6-sp
This is to help those who have questions about how to install the footwell lighting. You can connect the wire to any power source you like but the easiest to control without having to add another control is with the dimmer switch. I got these LED's off eBay, but I later found similar ones on dealextreme.com for cheaper.
Make sure you have required materials
More materials not pictured are wire stripper, extra cable and some heat shrink if you want.
pop the fuse cover off
Stick your fingers in to the left and pop the side cover off
Disconnect the dimmer switch
Use the wire stripper to strip the LED wire, and stick the wire into the slots as deep as you can, make sure you have a good connection
If you want the LED to dim with your dash lights connect the positive part of the LED to the purple wire and the negative part to the middle black wire
If you want them to dim opposite as in when you dim your dash lights, the LED's get brighter, connect the positive side of the LED to the middle black wire and negative to the outside black wire
Connect the dimmer switch back and test your lights.
While driving
from the outside
from the driver seat
For the passenger seat do the same making sure to run the wire through the groove
I haven't done the passenger seat yet because the LED's I bought came with short wire, so I need to find some wire and solder it to the LED wires. Hopefully will post pics within the week of that part
yankeefan0525
Car: 2008 Blue Nissan Versa SL
Instead of passing the wire through the grove there to get it into the passenger side, you might want to pass it behind the center console. What i mean is by the gas and brake pedals there is a space that goes directly into the passenger foot well. Just another idea for you but it is looking good.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
I bought the factory footwell LEDs and had the dealer install them, too lazy to do myself...lol
iluvmyVersa08
Car: 2008 Nissan Versa SL Sport
yankeefan0525 wrote:Instead of passing the wire through the grove there to get it into the passenger side, you might want to pass it behind the center console. What i mean is by the gas and brake pedals there is a space that goes directly into the passenger foot well. Just another idea for you but it is looking good.
That's exactly what I did when we installled the pink led's/neons under my footwells. That way the cord is not visible at all, and it fits in nicely behind there.
pavouk
Car: 2010 Versa S
What if you want the lights to com on only when the doors are open is there a wire nearby the dimmer switch that does provide power for the overhead light?
Thank you Michael
drovers
Car: 2009 Nissan Tiida S Hatchback
1.8 6 Speed Manual
Slate Grey
Pioneer AVIC-F310BT
I too have purchased LED strips off of ebay, however would like them to work off of the interior light door switch. Eg. LED's fade on and off with interior light, and can be forced on and off with the dome light switch if possible, otherwise, just fading in and out with the interior light would be fine.
Can anyone help me with the easiest way to wire this in/place to tap wires to accomplish this without pulling out the entire roof lining.
Thanks!
Strawmr
Car: 2007 Nissan Versa S Hatchback
dumb question, but which slots?
homero89
in the dimmer connector, look where there are three wire connected. Insert the cables into so the tip of the dimmer wires, and the tip of the LED wire touch. It should be a tight connection. The slot is where the wire touches the connector.
Also its better how yankeefan said it, pass the wire for the passenger LED behind the center console.
Strawmr
thanks man appreciate it. and appreciate the tutorial, once my leds come in this will be a great project
jolyrojr
Car: 2008 Versa SL HB, Red Alert, Stillen front and rear valence lip, Stillen wing and exhaust, cold air intake XXR 001 wheels, footwell lighting, hand made red led dome, almost no amber lights anywhere!
drovers wrote:I too have purchased LED strips off of ebay, however would like them to work off of the interior light door switch. Eg. LED's fade on and off with interior light, and can be forced on and off with the dome light switch if possible, otherwise, just fading in and out with the interior light would be fine.
Thanks!
I did a tutorial for doing this with dome/door function - interior-lighting-using-door-dome-function-t509289.html
edwin0621
Car: nissan tiida 2008
I understand nothing. can make a video tutorial to better understand please.
Grecia357
Car: Nissan Versa 2008 Sedan
I recently followed ur steps on my versa and the LED lights are on even tho I never turned on my car, is this okay or did I do something wrong ?
Return to “Versa Technical Discussions”
