what are the pros and cons of 2.5 inch cold pipe v.s. 2.25?c-rad wrote:Yeah, that's fine. Your piping is only as good as your throttle body. 2.5" would be the limit.
Throttle body necks down to a 2.75" outer diameter so the 3" is heavy overkill. The throttle plate itself is around 2" in diameter.Shogun wrote:I go with 3,1 inch on both sides (80 mm aluminium tubing).
sorry to bring this back to the dead, but I finally diagnosed mine, it was a slowly expanding exhaust manifold gasket leak. Just letting you know, maybe you can replace yours before it completely blows like mine did.Sir. Driftalot wrote:yea i do like the cooler i was going to go with a spearco but i got this for a very good price, so i couldnt pass it up.
im excited to see what kind of gains i get from this..
on a side note, my turbo makes a whistling noise from vacume into a couple psi of boost anyone know what it is. it almost sounds like police siren.
im goign to run it till money can afford for somthign different or it blows up any suggestions? t28 or?
