LIAR! my SE pulsar never had a CA18 in it....... um.... wait.... LIAR!themadscientist wrote:pulsar and sentra. They have a motor called the CA18 which is similar to the CA18.
I can honestly 100% without a doubt say that my SE pulsar has never had a CA18DE residing under the hood!Liquid_Neon wrote:LIAR! my SE pulsar never had a CA18 in it....... um.... wait.... LIAR!
good ol nissan messin with everyone's head by putting a very underpowered engine like the E or GA in a sporty pulsar.Kinda reminds me of the iron duke from another 'sporty' car that failed to live fully up to how it looks (and handles in the case of the pulsar).mazikowski wrote:Ah, you're a keen one! Yet, had it an E16i, it would no longer be an SE but an XE.
Mine is an '87 SE, powered by the wonderful CA16DE Well, used to be powered by a CA16DE. Now it's in the final stages of a CA18DET swap!
The CA16 models have low impediance injectors, has a smaller flywheel, and the rear seat is a crappy fake leather.themadscientist wrote:The CA16 is just an 18 with a 78mm bore.
From what I've seen, TMS, fast AE86's have a ca18 in themthemadscientist wrote:You could get 200hp out of a boosted E, they came turbo in some JDM models. Not exactly a doomday weapon but capable of shutting up a mouthy hachi roku.
The CA18DET has low impedance injectors, makes no difference.Liquid_Neon wrote:
no, they have 20 valve twin turbo 4As in them.I smoked the one CA18DET AE86 I have seen with my CA18DE S13.Liquid_Neon wrote:
Hey now... no oil squirters or girdle! (or however you spell that thing)themadscientist wrote:The CA16 is just an 18 with a 78mm bore.
The E15ET, sure... but that's EFI. The sad little E16s (all 69hp of it) is barely worth the metal it's made of.themadscientist wrote:You could get 200hp out of a boosted E, they came turbo in some JDM models. Not exactly a doomday weapon but capable of shutting up a mouthy hachi roku.
Actually, it's vinyl.Liquid_Neon wrote:...and the rear seat is a crappy fake leather.
Same differance I like my cloth rear seat and i wouldnt want it. You could always upgrade the seat with any old junkyard pulsar. The seats come out VERY easy!mazikowski wrote:Actually, it's vinyl.
not that i understood anything you wrote after that, but I beg to differ.ch187 wrote:just to reply to the thread starter. the pinto arp bolt DO NOT work.
EXACTLY. they are not the right length, tool.themadscientist wrote:Could be the wrong length. My Toda flywheel was thinner than the stocker and when I torqued it down the flywheel was still so loose I could wiggle it. I had to grind the bolts shorter.
did you personally soend the 30 bucks on the arp bolts? I did. and im telling you, THEY DONT WORK
