nitrogen »
https://forums.nicoclub.com/nitrogen-u54931.html
Fri Feb 02, 2007 10:18 am
I have a 2002 Infiniti I35.
I went and installed a directFM adapter for my sirius radio. It required me to pull off the passenger front panel (where the glove box is) and the side panel alongside the gear shifter, and on the side of the climate control and radio.
To do so, I disconnected an orange plug attached to the top of the flange where the latch for the glovebox is, as well as removing a light for the glovebox.
I also pulled the driver side front panel (disconnecting the switch for the automatic seat control) and driver side side panel.
After I reassembled everything, now my airbag light is flashing. Could disconnecting that yellow plug above the latch broken the airbag, or thrown a code?
Is there any way I can reset the CPU in the car w/o a code scanner to see if the light stops flashing, or did I do something really dumb here?
