Desert Rat wrote:The next bushings to look at are the leaf eye bushings. On 4x4s they get chewed up pretty good. Might still be ok on a truck that only sees road miles.
Mine were absolutely shot at 135K, all road miles, so definitely check them... They are a pain to remove, so be prepared with a hydraulic press, or use a sawsall to carefully cut the bushing sleeves out without damaging the springs. That was a tip I first read in this forum and thought it was kind of a redneck idea (no offense to the OP) and guess what finally got them out after all of my work with a big vice...
If you haven't replaced your shocks, that's a good idea too. Mine had lost every bit of pressure - staying wherever you put them. New ones made a HUGE difference.
Here's my suspension thread.
zerothread?id=356011
Heath
