scooterbob »
https://forums.nicoclub.com/scooterbob-u82760.html
Wed Feb 27, 2008 1:24 am
I'm not sure if Nissan uses any type of check valve in the oil filter system to prevent losing prime at the oil pump. If not, then it was probably just the initial startup of the engine/pump that you heard knocking. I would suggest you check the oil level, regardless if you just had it changed. Most dealers are decent enough to do an oil change, but periodically they make mistakes and may have left it a little to low or something.
Oil change intervals can be a debate that can go forever. It mostly depends on your preference, and then main guidlines of the manufacturer. I change mine at every 3000. I know the first one was at 3750, but after that I do it at 3k. Some people go anywhere from 3-5k before doing a change, but that depends on oil type, weight of oil, synthetic or not, and driving conditions/habits. The rest is personal preference IMO.
