finally my sr20 build
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
suppose to get those stickers next week
Magnum375 Jr.
Car: 1989 Nissan 240sx Hatchback
Dante, with a mph that high, you will tap low 15's. My mag did 15.104 @ 92.40 so i'm thinking you get your launch dialed in you could get a really decent pass out of it.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
yeah the launch was the biggest issue. if i wasnt spinning a one legger off the line, i would bog out if i didn't launch around 4500rpm
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So I ordered some drilled and slotted rotors with pads for the front and rear. I recieved them today and decided to just do the front today since the front passenger side was metal to metal. From the beginnimg i ran into problems. First the when I rook all the lug nuts off the driver's side the wheel wouldn't come off. The rust was stuck to the back of the wheel and after pounded it with a hammeer for about 5 min it finally broke loose. Then the next thing was the passenger caliper. Once everything was removed, I put the new rotor on and then the pads. Once i was ready to reinstall the top portion of the caliperl the piston was still out too far. So i tried using my brake compression tool to push the piston back in. After 15 minutes of trying I went over to the driver's side finished the entire side in about 3 minutes and the piston pushed back smoothly. So I tried the passenger side again and the piston would not budge. SEIZED damn. So I took the brake pads out and put the caliper back on left the brake pads out and parked the car. I will work on again later needed a break from it before I would break something trying to make it work
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
Finished all the brakes and rotors today and replaced the passenger front caliper. Now I just need to bleed the brakes, but I have to wait for one of parents to get home since no speed bleeders :facepalm: :gotme
replaced the driver's side wiper are so now the driver's wiper works again :squint:
the inside of the bushing wore out :wtf2:
Magnum375 Jr.
Wow, stock 240 brakes are SMALL, glad I had them z brakes. Glad you are making positive progress.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So I recieved my HIDs and tein s.tech lowering springs. Now just waiting for the time to put the stuff in. Been busy getting vehicles inspected. :naughty:
Then today after the hook-up for Doug's car, I picked up his old welded diff. Once thats fixed and the HIDs and springs are installed, I will be doing alot of practice sessions on some nice roads by my house. :ohno: :woot:
Magnum375 Jr.
Just make sure you put loctite on all those bolts on that gear inside the diff, or you'll have the same result he did.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
I'm going to order a new set of drive gear bolts and put them in.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So today I decide to tackle the Tein S.tech lowering springs. I started at about 11:30 a.m. The fronts took a good bit of time because I couldn't get the struts out, so I compressed the spring while it was still mounted. :tisk:
before springs about 4" gap all the way around :squint:
Unbolted the top nut and wiggle the spring out . Tein spring slipped right in without compressing them.
Front spring comparison
front springs in
Now the fronts have about a 2.5" gap :)
Then I got to the rear springs. They were even worse since I could get the rear struts out either. Getting the spring compressors in the tight space to work properly was a pain. :mad: :cry: I ended up unbolting the top on the rear spindle to give me more room to work with. Then I had to pry the spring out which then dropped the top of the strut. Once that was done the Tein springs went in smoothly.
the stock springs
comparing the rear springs
the rears installed
I finished this at 12:00 a.m. what a pain. Would have been so much easier if I could have taken the struts out.
I will take pics later of the new ride height just extremely tired now 12 straight hours for a small satisfaction. :wtf2:
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Hahaha damn dude! It took Bersh and I a while to get his coils on but DAMN all day?
Can't wait to see pics of this thing lowered.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So today I decide to work on the 240 again. The first thing i fixed was the broke wheel stud on the driver's front tire. Then bled the front driver's side brakes. Then proceeded to a oil change with Mobil 1 full synthetic high mileage 10W30. Suprisingly everything went smoothly and only took less than 20 minutes. :biggrin:
Then I decided to start on the H.I.D,s. Now that was a b!t$h. I couldnt find a good place to hide the ballast, then once I got everything in the right place there was a different plug for the HIDs that was suppose to plug into the stock one. So I cut the stock plug off the old headlight and wired it in the HID harness. Plug everything in, turned them on and they worked. BUT for some reason the high beams dont work and they are the dual filament bulbs. :squint: I gave up on a parked it. :inout: :werd:
Now for the new ride height. :woot:
Image really dont like the way the new headlights look :slap:
compare to the civic :gotme
the civic is even tucking tire :gotme
and the civic is just on eibach springs :gotme
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So today I decided to take the 240 out for a lil drive to see how the springs felt. Suprisingly the it was very comfortable and the lower center of gravity was nice. Went to the nissan dealer to pick up the drive gear bolt for the welded and headed to the mall. Came back outside from the mall to go home and when I started the it sounded like a subaru. :facepalm: I was only running on 3 cylinders. So I drove home to figure out is it was spark or fuel. I pulled the car in the garage and left it on. Then I popped the hood and started unplugging the injectors. Cylinder #2 was the only one that didn' cause the idle to drop or almost stall out when unplugged. So I go to take the cap off that holds the injector and one of the screws stripped. :mad: So I cut a slot across the top of the screw to use the biggest flathead screwdriver I have and that got the screw out. But I didn't pull the injector yet will get back to it later. I knew I would get frustrated with something. :inout:
So I decided to to put the new drive gear bolt in and torqued it down. Luckily that went in with no problems and now all I need is a diff cover. :woot:
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
Yesterday I finally got the injector out. I flipped the fuel rail over and tapped the injector with a hammer and it popped right out. :naughty: :tisk: The injector was destroyed from me trying to pry it out. :facepalm:
:gotme
Then today I went to autozone and picked up the new injector ($83 :bs: ) and a pack of o-rinngs.
The injector went in with no problems.
Plugged the injector in started her up and she purred like a kitten. :naughty:
ILoveMyRHS13
Yo I found a diff cover in my garage. I seriously don't know where I keep finding diff parts from. o.O
Come get it.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
ok sweet
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
I have random ka parts still AKA injectors. Coulda saved you 75 dollars lol.. :(
But hey, it's new.
bersh240
howd i miss this????
HI THERE!!
im kinda likin the greenish color even tho its rattle can.
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So the 240 started running crappy again but this time when I unplug injector #2 the car idles better, weird :gotme . So I went out and bought a Z32 TT fuel filter and put that on then I replaced the spark plugs with NGK V-power ones. Put new prostart wires on and and the car runs alot smoother now. :naughty:
stock fuel filter
TT z32 fuel filter
stock vs z32
z32 installed
NGK pulgs and prostart wires
the old plugs
Since I was changing out the plugs, I decided to do a compression.
cylinder #4
cylinder #3
cylinder #2
:squint: :tisk:
Dont have the picture for cylinder #1 but the gauge did not move and I took it out and put back in to try again but still nothing :wtf2: . When I checked cylinder #2 and pulled the gauge out there was some gas dripping out. My buddy at Autozone told that could be the reason why I didn't get a reading :poke: . But I also didn't have to pay for the compression tester just in case I broke it, which he thinks I did :werd: :slap:
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
Oh and the car was running like crap again so I pulled the #2 injector and it was the bottom o-ring. It was torn. So I replaced it and lubed the o-rings up put the injector back in and wahlah. Runs better than ever :crazy: :yesnod
So I installed my 5 panel wink mirror a couple of days ago. This thing is awesome. I don't even use my regular mirrors anymore. :naughty:
And I recieve my driver's side power window amp today. Took the door panel off, installed the switch and now I have a working power window :inoutgay: . Only if I would have known that was the problem a couple of months ago. :wtf2: :rolleyes:
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
CONSISTENT 15.8s @ Cecil County Dragway
(bone stock) :squint:
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
Sold the Civic added this to my toy collection
Using the extra money to work on the 240. :naughty:
Magnum375 Jr.
Awwww you sold the civic, how you getting back to texas?
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
now that the 240 is the only car and I got the motor running great, I am installing all the audio components and putting new tires on. Need to find some other wheels to put snow tires on though
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
So I finally got around to installing the welded diff. Let me just say installing a diff by yourself only using 2 jack stands and a floor jack sucks.
Went out to HomeDepot and bolt some new hardware.
Started off by unbolting the axle bolts that are attached to the diff.
Then I unbolted the rear sway bar to make it easier to get to the driveshaft bolts.
Onces I finished taking out all the bolts, I used the floor jack to help shimmy the axles out.
Then I used the floor jack again to install the welded but this wasnt as easy. Really sucks doing this alone but I got it installed. It took a little over 5hrs.
Now I just need an empty parking lot to take'm sideways
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
f*** welded diffs. ther suck to drive inthe rain, and i am drunk
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
anything is better than the open I had
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
Well I got bored again and decided to do some patch work on the driver's side floor panel. There was a hole right underneath the gas pedal. Attacked the sounddeadening with a wire wheel. :squint:
Then I took a steel 2" flat bar and cut it into 6" pieces then tacked them into a square.
Then welded the pieces together and tack welded the square to the floor
When I welded the entire way around the sqaure I caught the floor on fire a couple of times because I didnt remove all the sounddeadening. Got a little carried away with the welding. :facepalm:
Once the floor cooled off I sprayed with black truck bed liner.
I know the welds don't look the greatest but I was more worried about strength than aesthetics :inout:
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
lol i forgot making that post. some heavy duty patch work there
brn-n-jpn
Car: 89 240sx hatch
93 240sx hatch
97 expedition 4x4
yeah the patch is thicker than the floor lmao
