WAbernethy »
https://forums.nicoclub.com/wabernethy-u849.html
Tue Sep 30, 2003 10:55 am
I'm using a CT-26 from a Supra. It's not he best turbo for sure but it does make full boost from about 2500 to redline. I'm using 2" piping and running it through a starion I/C. My bottom end is original but still holds about 160 psi on all cylinders. Not sure about the humidity or pressure, but it was cool out, about 70 degrees. As far as having a boost leak, wouldn't that be rather noticeable? I mean, it seems to make boost quickly and holds it well. Wouldn't I have heard something while it was boosting on the dyno? I was looking under the hood while it was under full throttle/load. How can I check for this?
We gained about 20 hp overall. We tried to go a little leaner but got slight detonation. The readout from the wideband stays between 12.2 at lower rpm's to 11.6 at higher rpm's. I think it's tuned pretty well.
Back to my original questions, Has anyone dealt with this type of dyno setup? I'm wondering if this is one of those that reads lower figures when compared to others. What's the average power loss through a manual transmission?
I know the numbers sound low but it pulls like a crack whore on a glass pipe. Still haven't found anyone that wants to have a little showdown so I don't have anything to compare it to but time will tell. I did have some redneck in a full-size Ford try to take me but that was a joke. Had him by 3-4 carlengths before I got out of 2nd gear.
