finally got my car dynoed tuned. heres the results
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
yup yesturday i went to DRT to get my car tuned. as i originally said, my car was runnign really rich because of the larger injectors that i put in, and that i couldn't figure out how to tune the afc safely to get the thing to run good. so the initial baseline run was a dissapointing 186 at the wheels (around 240 crank hp). well after some tuning, i was actually able to hit a peak of 242 wheel hp ( 295 crank hp) but we could not get that number to come up again no matter how hard we tried. so we suspected that it was from the boost creep from the delta gate and that was creeping up to 10 psi. so we finally decided to settle for 232 wheel hp ( 284 crank hp ) and with a amazing 254 ft lb of torque at the wheels ( 310 ft lb of torque ). anyways thats not bad for a 4 cylinder with a $3000 kit only running 9 psi of boost eh? anyways to explain that dip after full boost, it is becuase as soon as the wastegate sees 9 psi, it bleeds off alittle too much boost, as i was reading hte boost gauge on the dyno it hits 9 psi, then drops to about 7, then goes back up to 8. otehr then that my power curve would've been flat like a plateau.
sorry for the poor quality of the scan. i was using my chairman's personaly comp and scanner. so i didn't want to go too crazy.
edit: nooooooo i can't put the pic up, it won' t let me post up a image bigger then 300X300
Phax
Car: Control dynamics
Congrats! Those are some good numbers. I look forward to seeing what the power band is like on that. How much the RPM band to expect to use during normal, day to day driving?
Structure240sx
so did they tune the afc or did u? how much did it cost u to get it tuned
S14tat
Car: 2007 FX35
1994 Acura NSX
they tuned it. the tuning was $250. i had around 23 pulls on the dyno. i guess i would post up the dyno. but i doubt you can see anything from just 300X300 resolution.
Structure240sx
thats a damn good deal i think
trpower7
damn right it is.
jhoward
Car: design, cars, music
cool. sounds like your car ought to run really good now.
S14tat
Car: 2007 FX35
1994 Acura NSX
yup. before the tuning, the car's turbo would not spool up as smoothly. the lag was definitly there, but when it hit, it hit hard. now after the tuning, the car's turbo spool up is alot more smoother. and the lag is almost gone.
#1 Stunna
If you would like, you can email it to me and I'll host it, so we can blow that mo fo up!
P.S Good numbers :D
Projex240
Car: Dogs , My RIDE
Just curious, have you ever thought of removing that random tech cat? using a test pipe, and then replacing for emissions would get you around 10-15 rwhp I think.give it a shot.
S14tat
Car: 2007 FX35
1994 Acura NSX
thanks #1 stunna you can private message me your e mail address. and projex240 i remember seeing sport compact car doin a test on high flow cats. and the random tech unit didn't lose any hp compared to their test pipe, and in fact, it gained 2 ft lb of torque. how does that work? i have no clue.
#1 Stunna
S14tat wrote:thanks #1 stunna you can private message me your e mail address. and projex240 i remember seeing sport compact car doin a test on high flow cats. and the random tech unit didn't lose any hp compared to their test pipe, and in fact, it gained 2 ft lb of torque. how does that work? i have no clue.
Here is my email [email protected] I tried to send you a PM but it said "administrator has disabled" or something like that. Thanks.
Ivan
Nathan
Off topic: how much did that random tech cat run you? did you just use a universal one?
andrave
Car: 1989 Nissan 240SX Coupe
actually SCC did a test on an NA vehicle for the random cat, with a turbo you are probably sacrificing some HP.In fact, SCC said that too.
