I think you should post some engine pictures. The car is a non-turbo.
What size are the rear tires? They don't look any wider than stock Z33 tires, but that could just be the pictures.
I also think you should get 1" adapters fro the front wheels to match the look of the rear wheels. Will also allow you to have properly fitting center caps.
Also, the B&M short throw shifter generally works better when it's INSTALLED, not sitting on the passenger floor:
I don't see how a twin turbo fuel gauge sending unit is going to work in a Z31. That sounds rather stupid.
I don't see how a 250mm twin turbo clutch is going to work in the Z31's NA transmission. It won't bolt to the flywheel.
Either you are full of it, or the person who sold you the car lied about a number of things.
cpns13 wrote:1989 Touring turbo Coupe, complete 3in mandel bent exhaust by c+m, twin turbo fuel pump & fuel gage sending unit, B&M short shifter, 250 MM twin turbo clutch, st perf springs, perf Nissan sway bars, perf Bil stein HD shocks + Struts, Solid mount rear suspension 350 Z wheels (rars widened by weld craft to 10 1/2). I think thats it let me know what you guys think.
http://i939.photobucket.com/al...1.jpgh ... al...m.jpg
Modified by cpns13 at 1:02 PM 12/2/2009
