Jerrybrown5081 »
https://forums.nicoclub.com/jerrybrown5081-u254540.html
Sun Feb 07, 2016 8:55 am
Ok, I'm stumped and need some help here... For the past several months, car had an idling issue. Would idle for a minute then idle super low and die out. Finally was able to get through and fix the issue, it caused my plugs to go out as well as ripped up some seals in my fuel rail, all replaced. Last weekend, finally got her together, she started and idled fine, but there was a dip in the idle when you'd hit the throttle. So I shut her off to investigate and one of the fuel injector seals had gone out and it was spewing fuel everywhere. They were only a few months old but like I said, that issue had ripped up a lot of seals. So, pulled her apart, replaced the seals on all the injectors, made sure everything else was new and in good order, put her back together same as before.... And she won't start. She turns, she's getting spark, fuel being pumped and the injectors are firing, I'm baffled. Everything worked fine, I just pulled the injectors and replaced the seals to fix the one that went bad.... Any help? I'm completely lost as to what could have gone out between last weekend and now.... triple and quadruple checked all my connections, wires and what not...
1996 Nissan 300ZX TT
Converted to OBD1
Selin dual intake
Ash Massive Intercoolers
2.5" Intercooler Piping
Greddy Boost Controller
740CC Nismo Injectors
Stage 3 RPS/SZ Clutch & Flywheel
SZ Turboback Exhaust
SZ Chip Tune
Spitfire coilpacks
Walboro 485 Fuel Pump
