Few Questions
B13-4dooR
Car: 1993 Nissan Sentra
hey everyone i might be doing a sr20 swap on my 93 4 door sentra and i was wondering if there was a diference between the se-r sr20 and the g20 sr20???
Another question is will my transmission bolt to a sr20 motor?? i have a 1.6L Ga16de i believe??
let me know guys. thanks
ABNRML4U
Car: Nissan B13
Welcome to NicoClub! Everyone here is nice and cool this is a general Info. that you need to know.GA16 -> SR20DE(T) swap info --------------------------------------------------------------------------------
-SR20DE(T) Motor-SR20DE FWD Transaxle-Driver side axle-Passenger side axle-Crossmember-All SR20 Motor mounts-Front motor mount bracket-Rear motor mount bracket-Transaxle mount-SE-R clutch cable (not needed if still using auto)-SE-R throttle cable-SE-R clutch cable bracket (bolts to transaxle)-SR20DE(T) ECU or G20 ECU (make sure if you're using OBDII or OBDI or use the right ECU)-SR20 clutch kit (throw out bearing, clutch disc, pressure plate)-SE-R wiring harness
Also you might want to check out some local shops that sells engines/trans.just give them the Info. on the list above on what parts to get. Believe me when I tell you, if your going to do this swap. Your Nissan will be a beast.
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
ABNRML4U wrote: Believe me when I tell you, if your going to do this swap. Your Nissan will be a beast.
Welcome and allow me to suggest an SR20DET from an Avenir. I don't know where mine came from, but I've heard good things about this place:
http://www.tigerjapanese.com/
And it's a ridiculous amount of power for such a lightweight car as a DD. I'm running the stock ecu at 7lbs and have trouble hooking up in second.
Mine was already an SE-R before the swap so you will most likely still need all that AB has posted.
BTW, AB, whatcha runnin?
B13-4dooR
Thanks for the info guys
im new to the nismo swaps im a honda guy but i have this now and i figured id put work into it this spring and summer.
but really thanks for the list of all i need. good looks
