NissanFairladyZ32 »
https://forums.nicoclub.com/nissanfairladyz32-u104963.html
Wed Oct 14, 2009 1:38 pm
First off i bought my z31 and the last owner put the z32 wheels on the car beacuse he liked the way they looked, what is the offset on the stock z31 wheel ? it seems the z32 wheels stick in alot ... is the offset the same on both wheels? i would like to go back to oem wheels if it would not stick in so much, i do not want to buy spacers
Second, It seems my doorlock assembley has broken from the inside of the car ( i have to roll the window down and open the car from the outside) on both door panels, does anyone know if nissan still makes the inside doorlock asembley ?
Third, What Diff & Rear End Gears came on the Z31 NA 1988 it feels like i have a lsd, it seems as if i lose the rear end quite easy & i can whip the car around as easy as i could a NA Miata i used to have with an lsd, it feels as if both wheels are spinning, is that normal for an NA ?
Pics are Examples of The Ugly Offset on the Z32 Wheels!
