biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Sat Jul 30, 2005 11:23 pm
that actually isn't a sensor, it's part of the idle assembly, that connector breaks for almost everyone.
basically, it's just turned on when the compressor kicks in, to raise the idle. no need to fix if you don't have ac, don't try to remove it just leave it as is. might be ok w/o it even w/ ac but you might stall occasionally if it kicks in at idle or when decellerating or something, depending on your luck and how well the engine is running.
