Fender Liner removal for CAI installation - PICS
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
As you can see in the instructions above, it asks for you to remove the "Push In Tabs" to remove the fender liner. For the guys who installed thier own CAI, how did you remove it? I tried to pry it with a flathead screwdriver but it didn't get me anywhere
CodeRed
Car: 2008 Nissan Versa S MT
You said you tried the flat head, well thats what I used and it worked fine.
shiryu0
use the flat screw driver to pop the center part out, then u can pull them out
Vice
shiryu0 wrote:use the flat screw driver to pop the center part out, then u can pull them out
Those things SUCK! I just did my headlight bulbs today and broke a few. Actually ended up hacksawing the last one off the bottom cover. Get some screw-type replacements (3/16") from Autozone and replace every one you remove.
Woody64
Car: 2008 Nissan Versa SL 6-Speed
Did you take those pictures you posted, or are you following a tutorial for installation? I am installing my Fujita CAI as soon as in comes in the mail, and other than pics of finished products and written directions, step by step would be helpful. Thanks alot
And I did search the forum, and found alot of posts, just not exactly what I am looking for...
2dr_sentra
Car: 1997 200SX SE-R, 2007 Versa SL 6spd
x2
have patience!
williamk10
I installed my Stillen Intake last night. Pretty straight forward (except for those !@#$ tabs). However, is the intake pipe supposed to be to close to the battery? It is currently touching the top right corner of the battery and about half and inch from touching the negative battery terminal
Does anyone experiance this with thier intakes?
#1Tango
my aem intake has rubbed against the metal where the sleeve is for your stillen intake. i have a nice gash on my intake and its wearing into the aluminum... i loosend it up and readjusted the intake and now it doesn't rub but i had to put some electrical tape on the edges cuz the body of the car would rub the intake significantly, i kinda wish the sleeve on the aem intake went down that far to protect it...
Return to “Versa Technical Discussions”
