faulty FSM? torque spec- head studs
tyrannix
Car: go big or go home
maybe im blind... but im pawing thru the FSM, about to put the head on my block... and i cant find the torque spec for it... unless im blind, it isnt in the eng mech section...
what is it? (and a page num if it is there and iam just blind?is it just the same as the main bolts?
themadscientist
My fsm lists a five step process. The figures are in metric though so you will have to convert.1. 3kg-m2. 10.5kg-m3. loosen to zero4. 3kg-m5.10.5kg-m
This must assume a stock gasket, some of the metal type compress once so I would not do the loosen retighten thing.The torque sequence is a radial pattern starting from the inside working out.
biosehnsucht
EM-27 for the diagram and instructions
the EDM FSM has it in several units including ft-lbs.
tyrannix
hmm... thats probably why i dont have it, just noticed my EM goes 24, 25, 26, 29, 30
can you post just pages 26,27,28,29 (so i can print them off double sided and fix my manual)
and 10.5 kg-m converts to 76 ft-lbs .. it that right? the mains werent even near that high
(my torque wrench reads in ft-lbs and N-M)
biosehnsucht
there's an already fixed FSM around
look in the 'CA18DET Wiring Information and FSM' sticky
3rd link, follow the instructions in the sticky to find it.
themadscientist
tyrannix wrote:hmm... thats probably why i dont have it, just noticed my EM goes 24, 25, 26, 29, 30
My Chiltons says 76ft lbs too so yup!
