Yello!
Soooo.
NHTSA ID: 25V-437
NISSAN ID: R25D1
1) "Nissan has identified potential manufacturing defects affecting engine bearings ". does this mean that if I get a set of newer part number bearings and replace them - issue solved?
1.1) parts.nissanusa.com - I don't seem to be able to even open section about "cylinder block components". section "bearings" only has something for camshaft.
2) potentially involved following components (
https://static.nhtsa.gov/odi/rcl/2025/R ... 7-0139.pdf ):
10102 4MUAA
10102 6RCAA (2023-2024)
10102 6RCAE (2023-2024)
10102 6RD0A seems that it is replaced by 10102 6RD1A
10102 6RD1A
10102 6RZ0A seems that it is replaced by 10102 6RD1A
can I find label in a car for our engine?
3) if this situation happens - are turbo and radiators/heat exchangers replaced too(if metal shavings are traveling in oiling system...)?
