nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Jan 28, 2016 8:29 pm
The install looks good. Personally, i would take it to another alignment tech. Its possible the tech may not know how to properly adjust everything in the correct order. I believe the correct order is caster, camber, toe. I know toe is always last. If he has never done a lowered car(assuming you are lowered), it can be discerning because he will need to get close to the numbers, it will not ride good in stock position or it may not go back into stock position(numbers).
Since you have all adjustable except lower control arms, it should go to a good number, not way off like he is saying it is.
