evildky wrote:oh boy...
Well gee thanks for taking the time.
evildky wrote:both cars use cv shafts, but the Z32 uses an output shaft that the cv shaft bolts to, the Z31 uses output shafts that are part of the cv shaft, U joints are only in your driveshaft (S30's and some S130's had U joints intheir axles but all Z31's and newer use CV shafts)
Good to know.
evildky wrote:there is no worm gear, there si a ring gear and a pinion gear, the ring gear si the one that bolts to the differential carrier, it is made to work wiht a specific pinion gear, and the pinior gear for the short nose case is shorter than the pinion gear on the long nose case hense the length of the different diff cases, so if you change your carrier you have to run the propper ring gear to match the pinion gear andevne then it needs to be adjusted using shims
Pinion is what transfers the motion of the driveshaft onto the ring gear, correct? It sort of looked like a worm-gear to me.
Anyway moving along... I understand I have to swap the ring gear and pinion over as a package in order for things to work, but how do you shim the pinion? It's not really visible when the carrier is there, so what's the secret?
evildky wrote:all 87.5-89 Z31 turbo's came fomr the factory with a clutch type R200 except the 88 ss (also known as the SE or Shiro edition) which came with the Viscous LSD
Cool. It's not really easy to find these CLSDs tho. eBay is asking for $850 for one.
