Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Sep 05, 2003 6:38 am
Unfortunately the expense of repairs is a function of miles driven [and local road conditions] and the precision requirements of the owner. And his financial capacity.
You have to breakdown the costs into during warranty, and the period to 100k- 125k [when you are just exceeding the designed in life] and 125-200k then the final 100k till 300,000 miles.
Using as designed oem tires which wore out in 15,000 miles would mean 6 replacements in 100,000 miles [6x4x $175= $4,200].........a tire that costs $100 but last 25,000 would cost $1600.........plus the 6 month alignments [$850] and 90 day rebalances [say $750].
So tires might really cost $6,000 or $3200 per 100,000 miles.....6 cents or 3.2 cents per mile.
Same with brakes, pads rotors, bleeding, retrueing: perfection cost money! It can cost $6,000 [plus another $2,000 for pads and rotors] to always have perfect brakes over 100,000 miles.
That's 8 cents a mile[most don't spend 2-3 cents per mile]!
Members can spend 14 or 5 cents or less per mile on just the two wear items.
I only spent $7,700 [including the $1000 for a 100k ext service contract......which returned over $8,000] because I used harder Michelin V4 tires and pretty much ignore the brakes as most driving was city.
When the car hit 100k it was worn out, it took a quick $12,000 over the next 2 years to get to 165k, then $3,000 per year thereafter to keep it right [4.5 x 3k=$13.5K +$12k+ $7.7K]$33,200 or $41,200 [if you count what the extended service contract paid out]..........12.8 or 15.8 cents per mile.
I expect to spend at least $3,000 per year over the next 2 years to get to 300,000 miles.........assumming the engine lasts.
Many of the things that were replaced in the 100-120,000 mile period are again in need of replacing 160-140,000 miles later.Motor mounts, drive shaft.
Many things were just replaced in the last few years:rear subframe, differential, 2 wheel bearings, alternator, AC system, all brake calipers, etc,etc.
I'll need at least 2 sets of tires, and a set of rotors and pads, $1000 in fluid changes, multiple trueing, balances, alignments, upper links, tension rods, some bushings, a battery,............65% of the money is known today!
Will only $1100 in other [unlisted/unknown parts [plus $850 in labor] fail in the next 40,000 miles. Will I live with 60k rear shocks.Will I live with a windshield with 2 cracks presently in it.
I have 4 spare injectors, KS, CAS, a MAF, ABS, alternator, an entire dash gauge assembly, spare modules ecu, tcu, and cheap access to lots of trashed Q.
No spare driveshaft, no spare transmission, no spare engine, .
You gotta plan ahead!
