Nitewulf »
https://forums.nicoclub.com/nitewulf-u127097.html
Sat Feb 21, 2009 4:33 pm
Parts one and two I agree with, however, you can have water in the exhaust long afer startup. if left idling for a long period of time after it has been hot from running, you can still develope moisture in your exhaust. Which as stated is a normal condition, though it seems strange that you could develope moisture in a high temp metal casing, the amount of cooling from the catalyst and your egr puts enough fresh air back in the system to produce moisture in the exhaust. On header or straight piped vehicles it isnt really a factor, due to the lack of the external air forced into the exhaust system.
