Joe wrote:on a turbo car all the backpressure the engine needs is created by the turbo so it really makes no difference what you do AFTER the turbo provided you arent choking it. a 4" is pointless and overkill but whatever you want man. a 3" will support you to 500whp if you really want it to. arguing the difference between .25 is like arguing who is hotter, kate beckinsale or bar rafeli. both are hot. both will get the job done.
I guess I should have prefaced my statement with 'turbo back'. I shouldn't have assumed that was what we were talking about, but I thought the apexi' and the custom system will be from the cat back, maybe even from the downpipe back, but either way not before the turbo?
Either way, the exhaust header/manifold you use, as well as the turbo it's coupled with also play a big role in how your exhaust works, which is what I believe joe was getting at when he talked about the turbo creating back pressure? From my understanding, the purpose of a custom built exhaust header is twofold; one, it is designed to line up exhaust pulses coming from each different cylinder, and two, it is designed to 'speed up' the exhaust gas velocity so that it can push the hot end of the turbo faster, thus speeding up things on the cold side too.
Heres my best explanation of what I am talking about 'lining up' exhaust gas pulses, hope its comprehendable. In a I-4 and I-6 engine, you have 4 and 6 different exhaust pulses respectively in one full cycle of the engine, which happens to be two full revolutions. These pulses happen in a sequence, just as your cylinders fire in a sequence, the exhaust valves open in a sequence, etc. etc. One more thing you need to know about these exhaust pulses is that they are comprised of three parts, the head (a high pressure area leading the exhaust out), the body (a medium pressure area containing most the exhaust gasses, and a tail (you guessed it, a low pressure area that trails this pulse we are talking about and creates a vacuum in the pulses wake). Now, if you have ever looked at one of those super expensive race headers for sr20's, rb25's etc etc, you will notice that each cylinder has its own individual primary tube coming from the exhaust ports which bends around in smooth twists with the other primary tubes from the other cylinders until they come together to either one or two different turbo flanges depending on the application. Anyways, the point of bending these pipes together, and trying to make them all the same length is to ensure that these different exhaust pulses 'line up' when they finally join into one tube before the they hit the turbo. This is a form of exhaust scavenging, using the tail of the previous exhaust pulse to effectively pull the next one out faster by creating a larger pressure difference in the system.
When you get into V shaped engines the headers become even crazier because you have competing exhaust pulses, but i'll leave that for someone else to explain.
Also, as I mentioned above, some headers are designed to actually squeeze the exhaust pulses thru the primary tubes thus speeding up exhaust speed. The reason for this is the faster your exhaust gasses are traveling when they reach the turbo, the faster the turbo should spin. And yes, this 'squeeze' is technically a form of back pressure, and by the loose definition of the word a turbo charger in itself is technically a form of back pressure as well. Cj explains this pretty well as he explains a bit about the subject of exhaust gas velocity, which in itself is another factor dealing with how exhaust systems work. However, one thing I would say is that it is not fair to go around telling people back pressure is good because by loose definition of the word how a turbo works is technically a form of back pressure. Turbos are good, but the back pressure created by the turbo is not actually good for how the exhaust gasses travel thru your exhaust; therefore, back pressure is still ALWAYS bad.
Exhaust gas velocity has a direct relation to exhaust gas temperature, and for this reason you can go too big sometimes, especially in the case of N/A cars, as Cj as touched on this subject. If the exhaust system is too big, from headers-back on n/a and from turbo-back on boosted apps, then the exhaust gasses will cool down considerably as they are traveling out the system, slowing them down, and thus reducing the overall effectiveness of your super-big, super-straight system.
And stockbee, trust me when i say this is definately not a noobish question, and many people have many answers to give you concerning this subject. If you want to learn a little bit more about exhaust systems, and how they work go check out this thread...
zerothread?id=456815
