FAM wrote: ↑Sun Jan 26, 2020 9:20 pm
I just got a 2018 Q70S 5.6! I already have a 2003 & 2004 Q45 4.5 which are what I'm comparing the Q70 5.6 too! The 5.6 seems awfully noisy and rough running, especially at cold starts ups! The oil seems to have a dark tint and not because dirty! The oil smells strongly of gasoline! The tailpipes seem to have more than normal soot! The 4.5's run like a whisper, in my mind as a V8 should. Is this 5.6 loud and rough running normal?
Yes the cold start up is more aggressive due to open loop where the ECU does not rely on O2 sensors to adjust A/F ratio. After about 20 - 25 seconds or so, it changes to closed loop, and the engine will smooth out. Also, the engine will run a little louder during the colder months because the outside air is more dense, so the A/F ratio will change a little to accommodate that.
The darker tint of the motor oil is indicative of using full synthetic vs conventional oil, so no worries there.
The 4.5 uses SFI where the fuel is injected before the intake valves. Since the 5.6 is a DI engine, the fuel is injected after the intake valve and directly into the cylinder. In the 5.6, it's normal for the exhaust tips to exhibit soot. I'm running the sport mufflers, so I made it a daily regimen to wipe my tips with a rag to keep them looking shiny. Also, the DI engine requires a small amount of oil to seep past the valve guide seals to help lubricate the guides. The 5.6 tends to blow a little excessive oil and gas vapors through the PCV valves into the intake. These vapors along with oil droplets are reburned in the engine to reduce emissions. Because of this, you'll need to check your oil levels in between scheduled oil changes, and this also explains the gas smell in your exhaust. While some folks (myself included) installed catch cans to help trap some of the excess oil, I found that proper functioning PCV valves keep the excessive blowby to a minimum. I ended up removing my cans and returned to stock configuration since I wasn't trapping that much once I replaced my PCV valves.
Both utilize the crossplane firing order 18736542 which basically means that you'll have 2 cylinders firing sequentially on the same side. This explains the more aggressive exhaust pulse and the need for a Y-pipe to help balance those pulses by merging the two exhaust banks into one stream.
All of the above is normal for the 5.6 engine...unfortunately, it's rough on the catalytic converters, which is another thread altogether...
