nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sat May 28, 2016 7:12 am
As far as aftermarket parts being balanced, if you get them from a reputable source, eagle, you should be just fine with the balance. If it was an internal balance issue, it would get much worse at 5k rpms not better.
Have you looked at your injectors? Are you sure you didn't mixup two adjacent cylinders(put 3in cylinder 4) for the injectors? WHat type of spark plugs are you using? If its a TT the gap could be too wide and blowing out the spark. NA could be fouled up or a weak plug, TT same thing. I would look more toward electronics vs rotating mass just because the engine smooths out at higher rpm's.
I had an injector die on me, new style, it would act like a miss at idle and have a wicked vibration randomly, but would always smooth out in the higher rpms. It tested good, it even passed the click test, but when I moved the injector to a different cylinder, it followed. Test your injectors(10-14 ohms), pull your plugs and see what they look like. Are some wet? are they dry and what color do they have? Are you using the correct plugs for the engine?
BTW an unbalanced rotating assembly will feel fine in the lower rpms, and worse in the higher rpms. Think of an unbalanced tired, will feel fine at the lower speeds, but you will notice a shimmy at about 40mph, will probably smooth out at 50 and come back hard at 65+.
