mrodrig2 »
https://forums.nicoclub.com/mrodrig2-u106864.html
Wed Nov 25, 2009 4:58 am
1) Get a service manual and follow the trouble shooting steps, it will be much more helpful to you in the long run.2) Try posting in the Nissan Mechanical Help forum, there doesn't seem to be a a whole lot of technical knowledge in the Altima forums.3) Start diagnosing each component prior to the plugs... Check your grounds first, then trace backwards until you find out where you aren't getting voltage. Distributor? Are the plug wires good? Are the plug wires in the correct sequence? Is your battery good? Your alternator? Your starter? .... ad nauseum
Modified by mrodrig2 at 8:55 AM 11/25/2009
