engine swapping
fredfarkel
OK, here goes....I noticed that on the Nissan Xterra, the engine number disifnation is the same...even on the SUPERCHARGED (VG33E) one! Does this mean that with the right ECU, harness and perhaps some other parts, you can swap out your old Pathfinder/QX4 engine to this?
PalmerWMD
Car: 2004 350Z
It would depend on the location of the motor mounts.Check their location on your car and a Pathy/QX4, if those are the same you should be able to pull it off.
Fred...:)
