z.Leinbach »
https://forums.nicoclub.com/z-leinbach-u254818.html
Mon Apr 11, 2016 10:39 pm
Well due to unfortunate events, I'm stupid low compression in 2 cylinders on the same bank, soon by the time I can afford to get around to it it will be time for a swap, I am considering a new block an fresh heads, decent support mods, (light weight flywheel, under drive pulleys, you all know) aiming for 200on the ground, anyway, was considering a jdm engine and a rebuild kit with a DETT oil pump, or would it be more cost effective to get a US engine and rebuild it, also is it possible to remove the engine WITHOUT evacing the R_12 as my AC still works and I can't afford he conversation, ideas? Addition, opinions all welcome (except for park it)
