Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Aug 27, 2008 8:16 am
Operating temp should be around 180 degrees. Hence the reason the thermostat opens at 170. Nismos open at 150 I think?
You can replace the temp gauge in your car pretty easily if you want to retain it.
But since you have an autometer gauge, I wuold run that instead as it's accurate. Where is your temp probe exactly at? A cross pipe going to the radiator?
Either or, you should have a power wire going to the probe, then to your gauge, then grounded. Or i might have that backwards. I can't remember which way is best all of a sudden.
As for the water in your exhaust pipe. Are you certain it's coolant? Or is it just condensation? Do any of your cylinders look lower than the others? By a significant amount? You may want to perform another compression check and also do a leakdown test. If you think you have a leaky headgasket (remember they CAN leak and not be blown), check to see if your coolant is bubbling and percolating when the car is running. Your radiator should look like it's burping a lot of air if you have a leak in the headgasket.
