Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Mar 30, 2009 5:47 am
162k on a VG bottom end is nothing really provided regular maintenance has been done on the motor.
That said, the swap isn't bad either. pull the radiator, unbolt the exhaust, and start unplugging wires. Nissan made this easy in the sense that no two plugs are the same, so you can't screw up reconnecting everything, though some of the plugs can be a bugger to get separated.
If you are swapping, it's a good time to bolt up new exhaust manifolds, water pump, and replace all belts/hoses. Most accessories (PS, AC, etc.) can be unbolted and laid to the side and tied up with zip ties to prevent having to remove them completely. I know you can get away with this on the 4 banger, and it looks like you can on the PS on the VG as well. AC I'm not sure, but it would save you having to dump freon and recharging the system if you can get away with it.
Obviously it's easier to get everyting out after pulling the radiator and shroud out as well. The crank sensor on the back of the engine should be removed and tied out of the way carefully, especially when you drop in the new motor, as it's easy to smash it between the block and the bellhousing.
I would also replace your motor mounts while you're in there as well.
