DanielC »
https://forums.nicoclub.com/danielc-u110482.html
Wed Dec 31, 1969 5:00 pm
I can sympthize with you, I hate having to give a machine shop a lot of money. Try to get them to give you a steady customer discount. I an also taking an automotive class at a local community college, and that can get me a discount. I recently went to a meeting of a local Datsun club here in Portland, Or (Datsun NW) and membership in the club cost $24.00, and the first purchase I made at a local auto parts chain, I saved over $20.00 off retail on that one invoice.
I have three useable Datsun L-16 cylinder heads, but all three need valve jobs. One was already apart, and the other two are still on the engine, and were blowing air past the valves on the leakdown test I did on them. I am actually considering buying some valve grinding equiptment. The best price I have gotten around here is $175 for a valve job on a Datsun 4 cylinder head. I would buy only the equiptment I need to grind (or cut) the valve seats, and not stuff I would need to replace guides, or seats.
The plan I have with the head that is apart is to get .003 O/S stem valves, to tighten up the clearance in the valve guides, and see if I can clean up the valve seats in the head by just lapping them with valve grinding compound.
Once again, I would pull the oil pan, clean it, and plastigauge the rod and main bearings. My service manual says Main bearing clearance is .0008 to .0028, Rod bearing clearance is .0006 to .0026. If you decide to put rings in the block, that is a possibility, you could borrow or buy a ball hone to put some tooth back in the cylinder walls to seat new rings. I have heard that Datsun blocks quite often do not wear enough to require boring to the next oversize every time you put rings in them.
I too have heard that doing a valve job can cause an engine to wear out rings, or bearings, but I am sceptical. I believe that the parts in question were already worn out, and would of failed anyway, but with bad valves, the engine would not run to make them fail. Do you think this is exciting enough for Mythbusters to take it on?
I understand that if you are patient, you can get a serviceable L-16 or L-18 block for not much money, most people want a bigger displacement engine to swap in.
A national chain of auto parts stores (Schuck's Auto Parts in this area) can sell you a rebuilt L-16 engine, I was quoted a price of around $1200, I think for a long block engine.
I will let you know how the oversized valves worked out in the head I am working on.
