ImStricken06 wrote: you want the thinnest oil in there as possible. thicker cold oil takes longer to make its rounds - so 0w-30 is optimal for turbo. plus 0w is synthetic.
strange...VW specs 5w-40 (yes a synthetic oil) for my turbo engine as the higher "hot weight" will handle the heat better. I'm sure a 5-30 or 0-30 would work in a pinch, but depending on climate (btw, I'm not in Canada or Alaska), I would not want to run the "30" oil very long. Interestingly enough, Mobil's 0w-40 (also a synthetic) meets the VW spec that is spec'd for my turbo engine. I (personally) would not run a conventional oil in my turbo or any turbo engine for that matter. [Our Pathfinder takes 5-30.] Maybe Amsoil, Royal Purple or BradPenn 30 weights can handle the heat; however, I haven't looked to see if they meet the VW 502 spec. A track day may warrant a higher spec oil due to higher temps and longer periods in a high rpm condition, but I don't do track days and I don't live in AZ either.
True, flow when cold is important, but shear resistance when hot is just as important if not more so. If it's super cold, I'd run the 0-40 and use an oil pan heater to ensure my oil has the viscosity to get to all the engine parts as quickly as possible.
ImStricken06 wrote: 0w-30 is an upsell. its called synthetic. they'll pass the costs along to the consumer. they dont use it, and charge you for the cheaper 5w30. you're being a little dramatic about this.... no?
Possibly...you never know. Again, service departments are in the business to sell you services and upsell whenever they can. I don't know what goes on "in the back". I can only "trust" that the guys/gals in the back are doing the right thing.
Why would a dealer limit themselves to only two types/weights of oil if they service cars that span a multitude of oil weights? I don't have knowledge on every oil spec'd for every Nissan engine in the last 10 years, but it would make sense to have each type on hand. If possible, have a conventional and synthetic of each type (if possible). If the 0-20 is only a synthetic and that is the oil for your engine, well, then I guess you'll be paying for synthetic oil changes regardless and that just goes with the ownership/maintenance costs of the car. I understand the upsell concept with synthetic oil vs conv. I don't know what the dealer's cost per quart is when bought in bulk, but if they get the "good" stuff at $3/qt, as an example, and then can sell it to you for $10/qt, well, more power to them. I guess we should be glad that the automotive business does not have as much markup as the diamond business (as a whole).
ImStricken06 wrote: why would they pour your oil down the drain, and waste their own oil - just to charge you the same amount??? dude, where do you come up with this stuff? lol
I see black helicopters almost daily
. I never said they would pour the oil you brought in down the drain. There's nothing wrong in asking for your old parts back. They are your parts/property...yes, so why not? [This is just my thought process.] However, if there is a core charge for the old part, e.g. alternator, then you don't get the part back, but you do some credit...fair enough. I asked for parts back when I had my timing belt changed. The only part I didn't get back was the tensioner as there was a credit for the core so it could get rebuild and resold as a reman'd part. If the dealer is going to throw them away, I can do that too. Or, if you are a bit eccentric
you can keep the parts and make 3D art to hang on the wall of the garage. No, I do not ask for my old tires back. If I did, I would have at least 12, maybe 13 and no where to put them.
I call'em like I see them; like a one-eyed umpire. Thanks for the conversation, but if you will excuse me, I'm making a new foil hat for my camping trip this weekend.
