Engine Issue Not Sure What.. Help!
hardbody90
Car: 1990 Hardbody
My engine ka24e will idle just fine sounds smooth but like if i accelerate the truck it will go but then studder and then go again. its does this in all other gears all the way up.. it doesnt do it when i floor it down the road and rip through the gears though.. my concern was first a dirty fuel filter but i replaced it and it wasnt.. plugs and wires are new.. so i dont know where to look at next.. any suggestions..?? i do have a leaky muffler but i doubt thats the issue..
InsertNameHere
Car: 92 Hardbody
maybe check your TPS, vacuum lines, and EGR valve.
Nitewulf
Car: 02 Nissan Frontier Crew Cab
Are you sure you have good flow on the catalytic converter? I have seen cases where a clogged catalyst will cause poor low end engine response. As the previous poster suggested, check and recheck vaccuum lines, also, you mentioned new wires and plugs, correct place and order, correct spark plug gap? Did you have the problem previous to changing them, or is this new since the change? Last thing, be sure you didn't move the distributor, with the wiring changes you made, have your timing checked.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Sounds like a sensor issue. You should go and get the computer scanned and that will give a more definitive solution to your problem. My thoughts are the Throttle Position Sensor(TPS) is cooked but a quick scan will confirm this.
Causes of stuttering during acceleration:
1) Mass air flow sensor circuit - Engine speed will not rise more than 2,400 rpm due to the fuel cut.
2) Throttle position sensor circuit - Throttle position will be determined based on the injected fuel amount and the engine speed. Therefore, acceleration will be poor.When engine is idling = Normal engine sounds and smooth operation.When accelerating = Poor acceleration, engine hesitation.
BOOSTFOOL
Car: 92 240sx hatch
check for vacuum leaks mainly close to the fpr
