ArmedAviator wrote:Is your tune configured for the increased-flow injectors? If not, it's running far too rich and likely at an A/F ratio making start near impossible.
When changing MAFs and injectors, it's incredibly important for the ECU tune to be tuned for these specific changes.
He did say he had Z1 tune his ECU and with the Selin unit, you do not need a tune for that.
Now that brings up another point from what armedaviator asked, did Z1 tune for a dual MAF setup? if they did and you are using Selin, that could definitely be a problem.
When it comes to the orings, did you use any lube or oil on the orings? did you push them on by hand or use the caps to force them on? Even though they were aligned, its still very easy to pinch those little bastards. If you smell fuel out of the exhaust, its very likely that is what happened. Check your plugs, if you have spark and they are still wet, that could be your issue. If all of them are wet, you might need to look toward the injectors being an issue.
