Engine doesn't run after plenum pull and few mods! HELP!
vereshchak
Car: 1990 300zx N/A
1990 300zx TT
I forgot to mention, it will not idle at all anymore (sometimes at like maybe 500rpm if i try to straighten it out and let off softly..sometimes). I removed and cleaned my IACV so i was hoping for a better idle! Could this be due to the IACV or possibly my TPS needs adjusting?
nissanfreak12
Car: 92 300zx 2+2 TT
Yes on both. Also make sure your timing is 13° btdc +/-2°
nissanfreak12
Also make sure you do not have any boost leaks.
vereshchak
Car: 1990 300zx N/A
1990 300zx TT
Timing is set to 13 degrees. I have to give it another boost leak test but I replaced all the silicone hoses and couplers so Id expect even less leaks now. After work today hopefully I can adjust my TPS and IACV. Hopefully that will help because manually idling your car at every stop is pretty annoying!
