Stryker14 »
https://forums.nicoclub.com/stryker14-u245065.html
Thu Mar 05, 2015 8:47 am
I bought a leak down tester. Three cylinders are at 14-15%. The other three sound like a stuck intake valve. I can feel air coming out of the intake.
Does anyone have a suggestion for freeing these valves? Remember the engine is out and on a stand.
My options are these:
1. Do like Ace said, go ahead and hone cylinders and rering, and do a valve job.
2. Do a valve job, skip the rings and hope test the compression on the other three cylinders once the valve job is done.
The problem with re ringing the cylinder is that if it is all the way apart, it starts the while I'm there syndrome. While I'm there, dip the block, do the bearings, grind the crankshaft, ect. I'm not poor, but come on, if I pull it apart figure another $1000. Crap. Thats on top of the $$$ for wiring harness, New Style injectors, Paint, interior, 120K maintenance, Seals and gaskets, Clutch, other sensors, Boost controller, new front bumper, A/C recharge, misc brackets, silicon hoses, ECU tune.
This all started with a convertible shell with a N/A block that I was just going to put back in after a seal kit and have a fun little car. Found a JDM TT just across the street from me and figured why not? This can get out of control real quick. Like a disease!
