Engine Cleaning
roe_wedge
Car: 1990 240 SX S13
Remember i am still a noob when it comes to all of this so dont rag on me too much.
While i still have my engine in the garage.. i want to clean it a bit make it look better on the outside as well.. what are some good ways to clean it and whats some big no no's and what not? thank you
c-rad
Car: 1991 Nissan 240SX w/CA18DET
paint
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
purple power... just dont leave it on for too long... spray the WHOLE motor/engine bay and spray w/ water REALLY REALLY good ... it took like 4 bottles to clean my bay/motor... pick it up @ a local advanced for like 3-4 bucks a bottle
fanta
Engine degreaser. A power washer comes in handy. Make sure to thoroughly clean and, if necessary, repair the bay to get rid of any rust or corrosion. Checking the condition of the steering rack is a good move, too.
silvia_ca18det
Car: 350whp ca18det drift silvia
breake cleaner works wonders, engine degreeser, to get those stained aluminum pieces back up to par use a soft wire wheel on a drill......
mbmbmb23
If you can.......load the engine into the back of a pickup truck (on a wooden skid or something) then take it to a local self serve car wash and go at it. Just make sure you've capped off places that shouldnt get water in them.
roe_wedge
my motor was outside for a while... and i had it covered with a tarp though but a couple of times it rained and more than once the tarp fell off and im sure my motor got rained on a bit... but its been dried out for a while.. do you think anything is hurt? my friend told me nothing would happen to it but im convinced hes a retard since hes ****ed up everything on my car so far.... would everything be ok? keep in mind the ECU and everything was out still attached to it
Pumaking
yea man your good, I as well had the same thing happen only difference is I had the Valve Covers off b/c of painting and my bros friend was stupid enough to lift up the cover the night before and not put it back and it rained hard and yup my motor was filled with water, we drained it along with the oil opened oil pan cleaned it up and everything is good as pie. As for your ecu and harness most of it is weather proof just to be safe air it out, use a blow dryer to be sure.
