Racingline »
https://forums.nicoclub.com/racingline-u84514.html
Thu Oct 15, 2009 12:23 pm
The endlinks never had an issue with snapping, the issue was some people were not tightening the nuts down properly and they were backing out, causing the bushings to fall off.
Loc-Tite is included in the packaging for good measure but not needed if the nuts are tightened properly. When installing the nuts, put on the first flanged nut good and tight so that roughly 1/2~5/8 of thread is showing. Next install the second nut so that it is tight to the first nut. Then using 2 wrenches loosen the first nut while tightening the second.
This motion of butting the nuts together will create a near permanent bond that will never back out and is exponentially stronger than a standard lock-nut.
The loc-tight is used on the bolts only.
Shoot me an email if you have any other questions
