qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Wed Apr 25, 2007 7:23 pm
Ok, did the 60 mph run. This one is with my 1993 NICO stage 1 ECU. Here's the screen shot. The A/F Base gauges were all at 100 most of the time although during this shot they were off a bit. Tire size is apparently skewing the speed numbers as the speedo said 60 but ECU talk didn't. Anything look suspect?
Don't know if you wanted the log but here it is.
Time, RPM, Timing, Throttle, Air Flow, AAC, O2 Sensor, Injector, Battery, Duty Cycle, O2 Sensor RH, Injector RH, Duty Cycle RH, Speed mph, Water Temp F, Econ MPG, A/F Base, A/F Base SL, A/F Base RH, A/F Base SL RH09:10:30.628, 1925, 70, 0.92, 2.17, 50, 0.12, 3.58, 13.76, 5, 0.1, 3.64, 5, 57, 180, 21, 100, 98, 101, 9809:10:30.898, 1938, 69, 0.92, 2.18, 50, 0.16, 3.58, 13.76, 5, 0.21, 3.64, 5, 57, 180, 21, 100, 98, 101, 9809:10:31.068, 1938, 70, 0.92, 2.18, 50, 0.22, 3.61, 13.84, 5, 0.57, 3.33, 5, 57, 180, 20, 100, 98, 101, 9809:10:31.239, 1950, 70, 0.92, 2.18, 49, 0.49, 3.6, 13.76, 5, 0.75, 3.3, 5, 57, 180, 20, 100, 98, 101, 9809:10:31.409, 1938, 70, 0.92, 2.18, 50, 0.76, 3.28, 13.76, 5, 0.75, 3.3, 5, 57, 180, 22, 100, 98, 101, 9809:10:31.589, 1925, 70, 0.92, 2.18, 50, 0.72, 3.3, 13.76, 5, 0.19, 3.64, 5, 57, 180, 22, 100, 98, 101, 9809:10:31.759, 1925, 70, 0.92, 2.18, 50, 0.13, 3.58, 13.76, 5, 0.54, 3.34, 5, 57, 180, 21, 100, 98, 100, 9809:10:31.930, 1900, 70, 0.92, 2.19, 50, 0.58, 3.42, 13.76, 5, 0.46, 3.38, 5, 57, 180, 22, 100, 98, 100, 9809:10:32.100, 1938, 69, 0.92, 2.19, 50, 0.12, 3.64, 13.76, 5, 0.8, 3.36, 5, 57, 180, 20, 100, 98, 100, 9809:10:32.270, 1938, 69, 0.92, 2.2, 50, 0.68, 3.38, 13.76, 5, 0.08, 3.68, 5, 57, 180, 22, 99, 98, 100, 9809:10:32.440, 1938, 69, 0.92, 2.2, 50, 0.67, 3.32, 13.76, 5, 0.38, 3.72, 6, 57, 180, 22, 99, 98, 100, 9809:10:32.611, 1925, 69, 0.92, 2.2, 50, 0.17, 3.68, 13.76, 5, 0.78, 3.4, 5, 57, 180, 20, 99, 98, 100, 9809:10:32.791, 1938, 69, 0.92, 2.2, 50, 0.14, 3.7, 13.76, 5, 0.14, 3.66, 5, 57, 180, 20, 99, 98, 100, 9809:10:32.961, 1925, 69, 0.94, 2.21, 50, 0.52, 3.44, 13.76, 5, 0.07, 3.76, 6, 57, 180, 22, 100, 98, 100, 9809:10:33.131, 1925, 69, 0.94, 2.2, 50, 0.71, 3.38, 13.76, 5, 0.73, 3.42, 5, 57, 178, 22, 100, 98, 100, 9809:10:33.302, 1925, 69, 0.94, 2.21, 50, 0.15, 3.7, 13.76, 5, 0.39, 3.7, 5, 57, 180, 20, 100, 98, 100, 9809:10:33.472, 1925, 69, 0.94, 2.21, 50, 0.19, 3.76, 13.76, 6, 0.06, 3.76, 6, 57, 180, 20, 100, 98, 100, 9809:10:33.642, 1925, 69, 0.92, 2.21, 50, 0.76, 3.42, 13.76, 5, 0.66, 3.44, 5, 57, 180, 22, 100, 98, 100, 9809:10:33.822, 1900, 69, 0.94, 2.21, 50, 0.45, 3.4, 13.76, 5, 0.67, 3.44, 5, 57, 180, 22, 100, 98, 100, 9809:10:33.993, 1938, 69, 0.94, 2.22, 50, 0.12, 3.7, 13.76, 5, 0.08, 3.7, 5, 57, 180, 20, 100, 98, 100, 9809:10:34.173, 1950, 69, 0.94, 2.2, 50, 0.4, 3.73, 13.68, 6, 0.25, 3.73, 6, 58, 180, 20, 100, 98, 100, 9809:10:34.343, 1925, 69, 0.94, 2.2, 50, 0.77, 3.4, 13.76, 5, 0.75, 3.42, 5, 58, 178, 22, 100, 98, 100, 9809:10:34.513, 1938, 69, 0.92, 2.2, 50, 0.37, 3.64, 13.76, 5, 0.53, 3.36, 5, 58, 178, 21, 100, 98, 100, 9809:10:34.684, 1938, 69, 0.94, 2.21, 50, 0.12, 3.7, 13.76, 5, 0.06, 3.72, 6, 58, 180, 20, 100, 98, 100, 9809:10:34.864, 1925, 70, 0.92, 2.2, 50, 0.37, 3.74, 13.76, 5, 0.44, 3.76, 6, 57, 178, 20, 100, 98, 100, 9809:10:35.024, 1938, 69, 0.94, 2.2, 50, 0.75, 3.34, 13.76, 5, 0.78, 3.36, 5, 57, 178, 22, 100, 98, 100, 9809:10:35.204, 1938, 69, 0.92, 2.22, 50, 0.36, 3.68, 13.76, 5, 0.18, 3.7, 5, 57, 178, 20, 100, 98, 100, 9809:10:35.364, 1938, 69, 0.94, 2.21, 50, 0.12, 3.72, 13.76, 6, 0.1, 3.74, 6, 57, 178, 20, 100, 98, 100, 9809:10:35.545, 1950, 69, 0.92, 2.2, 50, 0.56, 3.4, 13.76, 5, 0.75, 3.4, 5, 57, 178, 21, 100, 98, 100, 9809:10:35.715, 1950, 69, 0.92, 2.2, 50, 0.75, 3.36, 13.76, 5, 0.58, 3.34, 5, 57, 178, 22, 100, 98, 100, 9809:10:35.885, 1950, 69, 0.94, 2.2, 49, 0.26, 3.64, 13.76, 5, 0.08, 3.7, 6, 57, 180, 20, 100, 98, 100, 9809:10:36.055, 1925, 69, 0.92, 2.2, 50, 0.13, 3.7, 13.84, 5, 0.6, 3.44, 5, 57, 178, 20, 100, 98, 100, 9809:10:36.226, 1925, 69, 0.94, 2.19, 50, 0.63, 3.38, 13.76, 5, 0.73, 3.36, 5, 57, 178, 22, 100, 98, 100, 9809:10:36.396, 1938, 69, 0.94, 2.2, 50, 0.73, 3.33, 13.84, 5, 0.11, 3.65, 5, 57, 178, 22, 100, 98, 100, 9809:10:36.566, 1938, 69, 0.94, 2.2, 50, 0.15, 3.66, 13.76, 5, 0.15, 3.74, 6, 57, 178, 20, 100, 98, 100, 9809:10:36.746, 1925, 69, 0.94, 2.2, 50, 0.14, 3.72, 13.76, 5, 0.79, 3.4, 5, 57, 178, 20, 100, 98, 100, 9809:10:36.927, 1950, 69, 0.92, 2.2, 50, 0.67, 3.38, 13.76, 5, 0.25, 3.62, 5, 57, 178, 22, 100, 98, 100, 9809:10:37.107, 1950, 69, 0.92, 2.2, 50, 0.69, 3.34, 13.76, 5, 0.07, 3.68, 5, 58, 178, 22, 100, 98, 100, 9809:10:37.287, 1938, 70, 0.94, 2.2, 50, 0.14, 3.64, 13.76, 5, 0.65, 3.4, 5, 58, 178, 21, 100, 98, 100, 9809:10:37.468, 1925, 69, 0.92, 2.21, 50, 0.17, 3.76, 13.76, 6, 0.56, 3.38, 5, 58, 178, 20, 100, 98, 100, 9809:10:37.658, 1938, 69, 0.94, 2.21, 49, 0.75, 3.39, 13.76, 5, 0.07, 3.71, 5, 57, 178, 22, 100, 98, 100, 9809:10:37.848, 1938, 69, 0.94, 2.2, 50, 0.53, 3.34, 13.76, 5, 0.71, 3.4, 5, 57, 178, 22, 100, 98, 99, 9809:10:38.028, 1938, 70, 0.94, 2.2, 50, 0.12, 3.68, 13.76, 5, 0.43, 3.32, 5, 57, 178, 20, 100, 98, 99, 9809:10:38.209, 1925, 69, 0.94, 2.2, 49, 0.5, 3.41, 13.84, 5, 0.05, 3.69, 5, 57, 178, 22, 100, 98, 99, 9809:10:38.389, 1925, 69, 0.92, 2.21, 49, 0.74, 3.39, 13.76, 5, 0.62, 3.41, 5, 57, 178, 22, 100, 98, 99, 9809:10:38.579, 1950, 69, 0.92, 2.2, 50, 0.22, 3.6, 13.76, 5, 0.65, 3.32, 5, 57, 178, 20, 100, 98, 99, 9809:10:38.759, 1938, 69, 0.94, 2.21, 50, 0.12, 3.72, 13.76, 6, 0.06, 3.7, 5, 57, 178, 20, 100, 98, 99, 9809:10:38.950, 1950, 69, 0.94, 2.21, 49, 0.68, 3.4, 13.76, 5, 0.46, 3.4, 5, 57, 178, 21, 100, 98, 99, 9809:10:39.130, 1950, 69, 0.92, 2.2, 50, 0.73, 3.34, 13.76, 5, 0.72, 3.34, 5, 58, 178, 22, 100, 98, 99, 9809:10:39.320, 1975, 70, 0.92, 2.19, 49, 0.2, 3.55, 13.76, 5, 0.08, 3.57, 5, 58, 178, 21, 100, 98, 99, 9809:10:39.500, 1938, 69, 0.92, 2.2, 50, 0.12, 3.68, 13.76, 5, 0.16, 3.7, 5, 58, 178, 20, 100, 98, 99, 9809:10:39.681, 1950, 69, 0.92, 2.19, 50, 0.66, 3.34, 13.76, 5, 0.75, 3.32, 5, 58, 178, 22, 100, 98, 99, 9809:10:39.871, 1950, 70, 0.92, 2.18, 50, 0.71, 3.26, 13.76, 5, 0.14, 3.56, 5, 57, 178, 22, 100, 98, 99, 9809:10:40.051, 1938, 70, 0.92, 2.18, 50, 0.16, 3.56, 13.76, 5, 0.1, 3.64, 5, 57, 178, 21, 100, 98, 99, 9809:10:40.241, 1938, 70, 0.92, 2.18, 50, 0.14, 3.62, 13.76, 5, 0.77, 3.32, 5, 57, 178, 20, 100, 98, 100, 9809:10:40.422, 1938, 70, 0.92, 2.18, 50, 0.7, 3.32, 13.76, 5, 0.23, 3.6, 5, 57, 178, 22, 99, 98, 100, 9809:10:40.602, 1925, 70, 0.92, 2.18, 50, 0.65, 3.25, 13.84, 5, 0.12, 3.63, 5, 57, 178, 23, 99, 98, 100, 9809:10:40.782, 1938, 70, 0.92, 2.18, 50, 0.13, 3.56, 13.76, 5, 0.79, 3.3, 5, 57, 178, 21, 99, 98, 100, 9809:10:40.973, 1938, 70, 0.92, 2.18, 50, 0.24, 3.6, 13.76, 5, 0.16, 3.56, 5, 57, 178, 20, 99, 98, 99, 9809:10:41.153, 1938, 70, 0.92, 2.17, 50, 0.77, 3.24, 13.76, 5, 0.09, 3.58, 5, 57, 178, 23, 99, 98, 99, 9809:10:41.343, 1925, 70, 0.9, 2.17, 49, 0.47, 3.19, 13.76, 5, 0.76, 3.27, 5, 58, 178, 24, 99, 98, 99, 9809:10:41.523, 1938, 70, 0.9, 2.16, 50, 0.11, 3.48, 13.76, 5, 0.32, 3.48, 5, 58, 178, 21, 99, 98, 99, 9809:10:41.704, 1938, 70, 0.9, 2.16, 50, 0.32, 3.52, 13.76, 5, 0.06, 3.52, 5, 58, 178, 21, 99, 98, 99, 9809:10:41.894, 1938, 70, 0.9, 2.16, 50, 0.77, 3.18, 13.76, 5, 0.62, 3.24, 5, 57, 178, 23, 99, 98, 100, 9809:10:42.084, 1938, 70, 0.9, 2.14, 50, 0.46, 3.12, 13.76, 5, 0.69, 3.16, 5, 57, 178, 24, 99, 98, 100, 9809:10:42.254, 1938, 70, 0.9, 2.14, 50, 0.11, 3.42, 13.76, 5, 0.08, 3.46, 5, 57, 178, 21, 99, 98, 100, 9809:10:42.445, 1950, 70, 0.9, 2.14, 50, 0.26, 3.44, 13.76, 5, 0.32, 3.48, 5, 57, 178, 21, 99, 98, 100, 9809:10:42.625, 1950, 71, 0.9, 2.13, 50, 0.76, 3.1, 13.76, 5, 0.78, 3.12, 5, 58, 178, 24, 99, 98, 100, 9809:10:42.805, 1950, 71, 0.9, 2.14, 50, 0.45, 3.08, 13.76, 5, 0.13, 3.42, 5, 58, 178, 24, 99, 98, 100, 9809:10:42.995, 1950, 71, 0.9, 2.12, 49, 0.11, 3.36, 13.76, 5, 0.11, 3.42, 5, 58, 178, 22, 99, 98, 100, 9809:10:43.186, 1950, 71, 0.88, 2.12, 49, 0.38, 3.41, 13.76, 5, 0.73, 3.11, 5, 58, 178, 22, 99, 98, 100, 9809:10:43.366, 1950, 71, 0.88, 2.12, 50, 0.73, 3.06, 13.76, 4, 0.22, 3.36, 5, 57, 178, 24, 99, 98, 100, 9809:10:43.546, 1938, 71, 0.88, 2.12, 50, 0.25, 3.34, 13.76, 5, 0.09, 3.42, 5, 57, 178, 22, 99, 98, 100, 9809:10:43.727, 1938, 71, 0.88, 2.11, 50, 0.12, 3.35, 13.84, 5, 0.78, 3.09, 4, 57, 178, 22, 99, 98, 100, 9809:10:43.917, 1938, 71, 0.88, 2.1, 50, 0.7, 3.03, 13.84, 4, 0.37, 3.29, 5, 57, 178, 24, 99, 98, 100, 9809:10:44.097, 1938, 71, 0.88, 2.09, 50, 0.7, 2.98, 13.76, 4, 0.08, 3.32, 5, 58, 178, 25, 99, 98, 100, 9809:10:44.287, 1925, 71, 0.86, 2.08, 50, 0.15, 3.21, 13.84, 5, 0.76, 3.01, 4, 58, 178, 24, 99, 98, 100, 9809:10:44.468, 1925, 71, 0.86, 2.05, 50, 0.21, 3.2, 13.76, 5, 0.46, 2.92, 4, 58, 178, 24, 99, 98, 100, 9809:10:44.648, 1925, 71, 0.86, 2.06, 50, 0.75, 2.94, 13.76, 4, 0.05, 3.24, 5, 58, 178, 26, 99, 98, 100, 9809:10:44.828, 1938, 71, 0.86, 2.06, 49, 0.41, 3.12, 13.76, 5, 0.69, 2.96, 4, 57, 178, 24, 99, 98, 100, 9809:10:45.018, 1938, 71, 0.84, 2.04, 50, 0.12, 3.12, 13.76, 5, 0.74, 2.88, 4, 57, 178, 24, 99, 98, 100, 9809:10:45.209, 1950, 71, 0.84, 2.04, 50, 0.53, 2.86, 13.76, 4, 0.08, 3.12, 5, 57, 178, 26, 99, 98, 100, 9809:10:45.389, 1938, 71, 0.84, 2.02, 50, 0.74, 2.82, 13.76, 4, 0.41, 3.12, 5, 57, 178, 26, 99, 98, 100, 9809:10:45.569, 1950, 71, 0.84, 2.02, 50, 0.21, 3, 13.76, 4, 0.81, 2.8, 4, 58, 178, 25, 99, 98, 99, 9809:10:45.749, 1938, 71, 0.84, 2.02, 50, 0.11, 3.06, 13.76, 4, 0.16, 3.06, 4, 58, 178, 25, 99, 98, 99, 9809:10:45.940, 1938, 71, 0.84, 2.02, 49, 0.62, 2.83, 13.76, 4, 0.05, 3.09, 4, 58, 178, 27, 98, 98, 99, 9809:10:46.130, 1938, 71, 0.84, 2.02, 50, 0.72, 2.78, 13.68, 4, 0.67, 2.84, 4, 57, 178, 27, 98, 98, 99, 9809:10:46.310, 1925, 71, 0.84, 2.02, 50, 0.16, 3.04, 13.84, 4, 0.71, 2.82, 4, 57, 178, 24, 98, 98, 99, 9809:10:46.490, 1925, 71, 0.84, 2.02, 50, 0.11, 3.06, 13.84, 4, 0.07, 3.08, 4, 57, 178, 24, 98, 98, 99, 9809:10:46.671, 1925, 70, 0.84, 2.02, 50, 0.55, 2.84, 13.76, 4, 0.27, 3.12, 5, 57, 178, 26, 99, 98, 99, 9809:10:46.851, 1925, 70, 0.84, 2.02, 50, 0.75, 2.8, 13.76, 4, 0.78, 2.84, 4, 57, 178, 27, 99, 98, 99, 9809:10:47.041, 1938, 71, 0.84, 2.02, 50, 0.22, 2.88, 13.76, 4, 0.23, 2.92, 4, 57, 178, 26, 99, 98, 99, 9809:10:47.222, 1938, 71, 0.84, 2.02, 50, 0.09, 2.92, 13.84, 4, 0.04, 2.96, 4, 57, 178, 25, 99, 98, 99, 9809:10:47.412, 1938, 71, 0.84, 2.02, 50, 0.08, 2.94, 13.76, 4, 0.05, 2.98, 4, 57, 178, 25, 99, 98, 99, 9809:10:47.592, 1938, 70, 0.84, 2.01, 50, 0.1, 2.96, 13.76, 4, 0.07, 3, 4, 57, 178, 25, 99, 98, 99, 9809:10:47.772, 1938, 71, 0.84, 2.02, 49, 0.14, 3.01, 13.84, 4, 0.19, 3.05, 4, 57, 178, 24, 99, 98, 99, 9809:10:47.963, 1925, 70, 0.84, 2.03, 50, 0.53, 2.98, 13.76, 4, 0.71, 2.98, 4, 57, 178, 25, 98, 98, 98, 9809:10:48.143, 1900, 71, 0.84, 2.03, 50, 0.71, 2.98, 13.76, 4, 0.69, 2.98, 4, 57, 178, 25, 98, 98, 98, 9809:10:48.333, 1900, 70, 0.84, 2.04, 50, 0.65, 2.96, 13.76, 4, 0.34, 3.08, 4, 57, 178, 25, 98, 98, 100, 9809:10:48.513, 1925, 71, 0.84, 2.04, 49, 0.39, 3.03, 13.84, 4, 0.08, 3.11, 4, 57, 178, 24, 99, 98, 100, 9809:10:48.694, 1925, 71, 0.84, 2.04, 50, 0.12, 3.04, 13.84, 4, 0.42, 3.12, 5, 57, 178, 24, 99, 98, 100, 9809:10:48.884, 1938, 71, 0.84, 2.04, 49, 0.14, 3.07, 13.76, 4, 0.72, 2.99, 4, 57, 178, 24, 99, 98, 100, 9809:10:49.064, 1925, 71, 0.84, 2.05, 50, 0.52, 3.04, 13.76, 4, 0.35, 3.1, 4, 57, 178, 24, 99, 98, 100, 9809:10:49.254, 1925, 71, 0.86, 2.04, 50, 0.71, 2.98, 13.76, 4, 0.09, 3.12, 5, 57, 178, 25, 99, 98, 100, 9809:10:49.435, 1900, 70, 0.86, 2.06, 50, 0.61, 3.01, 13.84, 4, 0.47, 3.09, 4, 57, 178, 25, 99, 98, 100, 9809:10:49.615, 1925, 71, 0.86, 2.06, 50, 0.31, 3.08, 13.76, 4, 0.71, 3.04, 4, 57, 178, 24, 99, 98, 100, 9809:10:49.795, 1925, 70, 0.86, 2.06, 49, 0.14, 3.14, 13.76, 5, 0.37, 3.14, 5, 57, 178, 24, 99, 98, 100, 9809:10:49.986, 1925, 70, 0.86, 2.07, 50, 0.16, 3.2, 13.76, 5, 0.08, 3.2, 5, 57, 178, 23, 99, 98, 100, 9809:10:50.176, 1925, 71, 0.86, 2.07, 50, 0.69, 3.07, 13.84, 4, 0.18, 3.23, 5, 57, 178, 24, 99, 98, 100, 9809:10:50.356, 1925, 71, 0.86, 2.08, 50, 0.72, 3.07, 13.84, 4, 0.7, 3.13, 5, 57, 178, 24, 99, 98, 101, 9809:10:50.536, 1925, 70, 0.86, 2.08, 49, 0.55, 3.02, 13.76, 4, 0.75, 3.1, 4, 57, 178, 25, 99, 98, 101, 9809:10:50.717, 1925, 71, 0.86, 2.08, 49, 0.16, 3.17, 13.84, 5, 0.39, 3.19, 5, 57, 178, 23, 100, 98, 101, 9809:10:50.897, 1900, 71, 0.86, 2.08, 50, 0.13, 3.25, 13.84, 5, 0.09, 3.27, 5, 57, 178, 23, 100, 98, 101, 9809:10:51.097, 1925, 71, 0.88, 2.09, 49, 0.3, 3.27, 13.76, 5, 0.38, 3.31, 5, 57, 178, 23, 100, 98, 101, 9809:10:51.277, 1900, 71, 0.88, 2.1, 49, 0.74, 3.22, 13.76, 5, 0.77, 3.26, 5, 57, 178, 23, 100, 98, 101, 9809:10:51.538, 1900, 71, 0.88, 2.11, 49, 0.68, 3.18, 13.76, 5, 0.47, 3.2, 5, 57, 178, 24, 100, 98, 101, 9809:10:51.858, 1925, 69, 0.88, 2.12, 50, 0.15, 3.28, 13.76, 5, 0.1, 3.38, 5, 57, 178, 23, 99, 98, 101, 9809:10:52.048, 1900, 71, 0.88, 2.12, 50, 0.15, 3.38, 13.76, 5, 0.64, 3.34, 5, 57, 178, 22, 99, 98, 101, 9809:10:52.229, 1925, 69, 0.9, 2.13, 50, 0.56, 3.27, 13.84, 5, 0.72, 3.27, 5, 57, 178, 23, 99, 98, 101, 9809:10:52.419, 1938, 69, 0.9, 2.14, 50, 0.73, 3.24, 13.76, 5, 0.19, 3.38, 5, 57, 178, 23, 99, 98, 101, 9809:10:52.599, 1925, 69, 0.9, 2.14, 50, 0.64, 3.24, 13.76, 5, 0.14, 3.46, 5, 57, 178, 23, 99, 98, 101, 9809:10:52.780, 1900, 70, 0.9, 2.13, 49, 0.27, 3.36, 13.76, 5, 0.59, 3.36, 5, 57, 178, 22, 99, 98, 101, 9809:10:52.960, 1925, 70, 0.9, 2.14, 50, 0.13, 3.39, 13.84, 5, 0.71, 3.33, 5, 57, 178, 22, 99, 98, 101, 9809:10:53.150, 1888, 70, 0.9, 2.14, 49, 0.18, 3.52, 13.76, 5, 0.15, 3.5, 5, 57, 178, 21, 99, 98, 101, 9809:10:53.330, 1900, 69, 0.9, 2.15, 49, 0.73, 3.36, 13.76, 5, 0.14, 3.54, 5, 56, 178, 22, 99, 98, 101, 9809:10:53.511, 1900, 70, 0.9, 2.14, 50, 0.74, 3.32, 13.84, 5, 0.72, 3.4, 5, 56, 178, 22, 99, 98, 101, 9809:10:53.701, 1900, 69, 0.9, 2.14, 49, 0.58, 3.25, 13.76, 5, 0.71, 3.31, 5, 56, 178, 23, 99, 98, 101, 9809:10:53.881, 1925, 69, 0.9, 2.14, 49, 0.16, 3.35, 13.76, 5, 0.17, 3.41, 5, 56, 178, 22, 99, 98, 101, 9809:10:54.071, 1938, 69, 0.9, 2.15, 49, 0.13, 3.39, 13.76, 5, 0.12, 3.45, 5, 57, 178, 22, 99, 98, 101, 9809:10:54.252, 1925, 70, 0.9, 2.16, 50, 0.21, 3.47, 13.76, 5, 0.63, 3.39, 5, 57, 178, 21, 99, 98, 101, 9809:10:54.432, 1925, 70, 0.9, 2.15, 50, 0.72, 3.34, 13.76, 5, 0.72, 3.34, 5, 57, 178, 22, 99, 98, 101, 9809:10:54.612, 1900, 70, 0.9, 2.16, 50, 0.71, 3.36, 13.84, 5, 0.23, 3.52, 5, 57, 178, 22, 99, 98, 101, 9809:10:54.802, 1900, 70, 0.9, 2.17, 49, 0.35, 3.47, 13.84, 5, 0.13, 3.57, 5, 57, 178, 22, 100, 98, 101, 9809:10:54.973, 1925, 70, 0.9, 2.16, 49, 0.13, 3.45, 13.84, 5, 0.64, 3.41, 5, 57, 178, 21, 100, 98, 101, 9809:10:55.173, 1925, 70, 0.9, 2.17, 50, 0.15, 3.52, 13.76, 5, 0.72, 3.38, 5, 57, 178, 21, 100, 98, 101, 9809:10:55.353, 1938, 69, 0.9, 2.16, 49, 0.46, 3.53, 13.84, 5, 0.15, 3.45, 5, 57, 178, 21, 100, 98, 101, 9809:10:55.533, 1938, 70, 0.92, 2.18, 50, 0.77, 3.41, 13.84, 5, 0.08, 3.57, 5, 57, 178, 22, 100, 98, 101, 9809:10:55.714, 1925, 70, 0.92, 2.18, 50, 0.76, 3.38, 13.76, 5, 0.58, 3.48, 5, 57, 178, 22, 100, 98, 101, 9809:10:55.894, 1900, 69, 0.92, 2.18, 49, 0.64, 3.37, 13.84, 5, 0.78, 3.47, 5, 57, 178, 22, 100, 98, 101, 9809:10:56.084, 1900, 70, 0.92, 2.18, 50, 0.22, 3.51, 13.84, 5, 0.64, 3.45, 5, 57, 178, 21, 100, 98, 101, 9809:10:56.275, 1925, 70, 0.92, 2.18, 50, 0.14, 3.51, 13.84, 5, 0.12, 3.53, 5, 57, 178, 21, 100, 98, 100, 9809:10:56.455, 1938, 70, 0.92, 2.18, 49, 0.29, 3.57, 13.84, 5, 0.13, 3.59, 5, 57, 178, 21, 100, 98, 100, 9809:10:56.635, 1938, 70, 0.92, 2.18, 49, 0.72, 3.37, 13.76, 5, 0.68, 3.43, 5, 57, 178, 22, 99, 98, 100, 9909:10:56.815, 1938, 70, 0.92, 2.18, 50, 0.64, 3.36, 13.76, 5, 0.7, 3.42, 5, 57, 178, 22, 99, 98, 100, 9909:10:56.996, 1938, 70, 0.92, 2.19, 50, 0.2, 3.52, 13.76, 5, 0.14, 3.6, 5, 57, 178, 21, 100, 98, 101, 9909:10:57.186, 1925, 70, 0.92, 2.19, 49, 0.14, 3.59, 13.84, 5, 0.36, 3.67, 5, 57, 178, 21, 100, 98, 101, 9909:10:57.366, 1925, 68, 0.92, 2.18, 50, 0.39, 3.62, 13.84, 5, 0.78, 3.46, 5, 57, 178, 20, 100, 98, 100, 9909:10:57.546, 1925, 70, 0.92, 2.19, 50, 0.74, 3.46, 13.76, 5, 0.57, 3.44, 5, 57, 178, 21, 100, 98, 100, 9909:10:57.727, 1938, 69, 0.92, 2.2, 49, 0.68, 3.42, 13.76, 5, 0.12, 3.6, 5, 57, 178, 21, 100, 98, 100, 9909:10:57.917, 1938, 70, 0.92, 2.19, 49, 0.32, 3.5, 13.76, 5, 0.22, 3.64, 5, 57, 178, 21, 100, 98, 100, 9909:10:58.097, 1950, 70, 0.92, 2.19, 49, 0.13, 3.52, 13.76, 5, 0.76, 3.44, 5, 57, 178, 21, 100, 98, 100, 9909:10:58.287, 1938, 70, 0.92, 2.18, 50, 0.19, 3.58, 13.76, 5, 0.52, 3.4, 5, 57, 178, 21, 100, 98, 100, 9909:10:58.468, 1925, 69, 0.92, 2.19, 50, 0.72, 3.5, 13.76, 5, 0.09, 3.62, 5, 57, 178, 21, 100, 98, 100, 9909:10:58.648, 1938, 69, 0.92, 2.2, 49, 0.69, 3.45, 13.84, 5, 0.38, 3.67, 5, 57, 178, 21, 100, 98, 100, 9909:10:58.838, 1925, 69, 0.92, 2.19, 50, 0.35, 3.54, 13.84, 5, 0.8, 3.5, 5, 58, 178, 21, 100, 98, 100, 9909:10:59.018, 1938, 68, 0.92, 2.19, 50, 0.14, 3.53, 13.84, 5, 0.73, 3.41, 5, 58, 178, 21, 100, 98, 100, 9909:10:59.209, 1925, 70, 0.92, 2.19, 49, 0.28, 3.61, 13.84, 5, 0.13, 3.55, 5, 58, 178, 21, 100, 98, 100, 9909:10:59.399, 1938, 70, 0.92, 2.19, 50, 0.73, 3.45, 13.84, 5, 0.1, 3.61, 5, 58, 178, 22, 100, 98, 100, 9909:10:59.589, 1938, 70, 0.92, 2.19, 50, 0.61, 3.4, 13.76, 5, 0.64, 3.48, 5, 57, 178, 22, 100, 98, 100, 9909:10:59.780, 1938, 69, 0.92, 2.2, 49, 0.17, 3.58, 13.76, 5, 0.74, 3.48, 5, 57, 178, 21, 100, 98, 100, 9909:10:59.960, 1950, 70, 0.92, 2.19, 49, 0.16, 3.55, 13.84, 5, 0.28, 3.51, 5, 57, 178, 21, 100, 98, 100, 9909:11:00.150, 1938, 70, 0.92, 2.19, 50, 0.49, 3.5, 13.76, 5, 0.09, 3.6, 5, 57, 178, 21, 100, 98, 100, 9909:11:00.330, 1938, 70, 0.92, 2.18, 50, 0.75, 3.4, 13.76, 5, 0.37, 3.6, 5, 57, 178, 22, 100, 98, 100, 9909:11:00.521, 1950, 70, 0.92, 2.18, 50, 0.6, 3.34, 13.76, 5, 0.76, 3.42, 5, 57, 178, 22, 100, 98, 100, 9909:11:00.701, 1950, 70, 0.92, 2.18, 50, 0.16, 3.48, 13.76, 5, 0.43, 3.38, 5, 57, 178, 21, 100, 98, 100, 9909:11:00.881, 1925, 70, 0.92, 2.19, 49, 0.14, 3.58, 13.76, 5, 0.09, 3.6, 5, 57, 178, 21, 100, 98, 100, 9909:11:01.061, 1938, 70, 0.92, 2.18, 49, 0.3, 3.6, 13.76, 5, 0.47, 3.6, 5, 57, 178, 20, 100, 98, 100, 9909:11:01.252, 1938, 70, 0.92, 2.18, 50, 0.73, 3.44, 13.76, 5, 0.77, 3.44, 5, 57, 178, 21, 100, 98, 100, 9909:11:01.442, 1925, 70, 0.92, 2.18, 50, 0.69, 3.4, 13.76, 5, 0.5, 3.4, 5, 57, 178, 22, 100, 98, 100, 9909:11:01.632, 1938, 70, 0.92, 2.17, 50, 0.37, 3.42, 13.84, 5, 0.09, 3.5, 5, 57, 178, 21, 100, 98, 100, 9909:11:01.813, 1938, 70, 0.92, 2.18, 50, 0.13, 3.49, 13.84, 5, 0.14, 3.57, 5, 58, 178, 21, 100, 98, 100, 9909:11:02.013, 1950, 70, 0.92, 2.16, 50, 0.21, 3.49, 13.84, 5, 0.74, 3.39, 5, 58, 178, 21, 100, 98, 100, 9909:11:02.203, 1950, 70, 0.92, 2.18, 50, 0.68, 3.39, 13.84, 5, 0.71, 3.35, 5, 58, 178, 22, 100, 98, 100, 9909:11:02.393, 1938, 70, 0.9, 2.17, 50, 0.73, 3.33, 13.84, 5, 0.27, 3.45, 5, 57, 178, 22, 100, 98, 100, 9909:11:02.584, 1950, 70, 0.9, 2.16, 50, 0.46, 3.24, 13.76, 5, 0.1, 3.44, 5, 57, 178, 23, 100, 98, 100, 9909:11:02.764, 1975, 70, 0.9, 2.16, 50, 0.14, 3.4, 13.76, 5, 0.24, 3.48, 5, 57, 178, 21, 100, 98, 100, 9909:11:02.954, 1950, 70, 0.9, 2.16, 50, 0.16, 3.46, 13.76, 5, 0.74, 3.36, 5, 57, 178, 21, 100, 98, 100, 9909:11:03.134, 1950, 70, 0.9, 2.16, 49, 0.66, 3.34, 13.76, 5, 0.51, 3.3, 5, 58, 178, 22, 100, 98, 100, 9909:11:03.325, 1950, 70, 0.9, 2.15, 49, 0.75, 3.26, 13.76, 5, 0.11, 3.42, 5, 58, 178, 23, 100, 98, 101, 9909:11:03.505, 1950, 70, 0.9, 2.16, 49, 0.63, 3.26, 13.76, 5, 0.19, 3.5, 5, 58, 178, 23, 100, 98, 101, 9909:11:03.705, 1950, 70, 0.9, 2.14, 49, 0.24, 3.34, 13.76, 5, 0.74, 3.3, 5, 58, 178, 22, 100, 98, 101, 9909:11:03.896, 1950, 70, 0.9, 2.15, 49, 0.15, 3.39, 13.84, 5, 0.69, 3.27, 5, 57, 178, 22, 100, 98, 101, 9909:11:04.076, 1938, 71, 0.9, 2.13, 49, 0.33, 3.37, 13.76, 5, 0.17, 3.35, 5, 57, 178, 22, 100, 98, 101, 9909:11:04.266, 1938, 71, 0.88, 2.12, 49, 0.74, 3.19, 13.84, 5, 0.16, 3.35, 5, 57, 178, 23, 99, 98, 101, 9909:11:04.446, 1925, 70, 0.88, 2.12, 49, 0.66, 3.19, 13.84, 5, 0.75, 3.25, 5, 57, 178, 23, 99, 98, 100, 9909:11:04.627, 1938, 71, 0.88, 2.1, 50, 0.43, 3.19, 13.84, 5, 0.75, 3.13, 5, 58, 178, 23, 99, 98, 100, 9909:11:04.807, 1925, 71, 0.88, 2.09, 50, 0.14, 3.21, 13.84, 5, 0.27, 3.21, 5, 58, 178, 24, 99, 98, 100, 9909:11:04.987, 1938, 71, 0.86, 2.08, 50, 0.19, 3.2, 13.76, 5, 0.09, 3.22, 5, 58, 178, 23, 99, 98, 100, 9909:11:05.177, 1938, 71, 0.86, 2.08, 50, 0.71, 3.08, 13.76, 4, 0.37, 3.22, 5, 58, 178, 24, 99, 98, 100, 9909:11:05.368, 1938, 71, 0.86, 2.06, 50, 0.76, 3.01, 13.84, 4, 0.78, 3.05, 4, 57, 178, 24, 99, 98, 100, 9909:11:05.548, 1938, 71, 0.86, 2.06, 49, 0.66, 2.96, 13.76, 4, 0.72, 3.02, 4, 57, 178, 25, 99, 98, 100, 9909:11:05.728, 1938, 71, 0.86, 2.06, 50, 0.27, 3.08, 13.76, 4, 0.25, 3.12, 5, 57, 178, 24, 99, 98, 99, 99
